Old 11-16-2021, 08:32 AM   #1
DylansZLE
DylansZLE's Avatar
Drives: 2022 Rapid Blue ZLE
Trufiber or Anderson Composites?
As the title implies Id like some opinions on whether to go with Anderson Composites or Trufiber to switch out some of the plastic on the exterior of my ZL1 1LE. Trufiber is a bit less expensive, but that may not mean less quality. Thoughts?
2022 Rapid Blue ZL1 1LE order ZNWPCX
Ordered - April 8, 2021 // 2000 - July 30, 2021
3000 - August 3, 2021 // 3100 - August 6, 2021
TPW - August 30
3300 - August 21 // 3400 - August 21
3800 10/18 // 4150 Oct 22
6000 November 1st
Instagram: dylanszle
DylansZLE is offline   Reply With Quote
Old 11-16-2021, 10:49 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
plastic on the interior? what parts are we talking about
Old 11-16-2021, 11:00 AM   #3
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Exterior.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 11-16-2021, 11:01 AM   #4
AZ_SS
AZ_SS's Avatar
Drives: 2018 Camaro ZL1 M6
He said exterior.
AZ_SS is offline   Reply With Quote
Old 11-16-2021, 11:05 AM   #5
kropscamaro16
ive seen alot of anderson parts in person really nice stuff !
Old 11-16-2021, 12:23 PM   #6
AZIROC
Drives: '86 IROC-Z '18 ZL1
Both make a great product. Unfortunately both are WAY behind when it comes to what's in stock and what's on back order. I can't speak for TruFiber, but if its OOS with Anderson, you are looking at a MINIMUM 12-16 week wait. as far as quality, but are top notch. I have the Anderson 1le spoiler and its amazing. I also have the trufiber canards and bezels. Again, look amazing. If you go with either you won't be disappointed. As you said, the TruFiber is usually less expensive.
Old 11-16-2021, 12:36 PM   #7
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Ordered an Anderson Composites ZLE spoiler in October of 2020, didn't receive it until May 2021. Their jig was also off slightly so I had to field destroy it and get my money back because they did not know how long it would be until they would fix the jigs and be able to make more spoilers. The carbon fiber finish looked awesome and I felt terrible destroying it but it didn't fit dropping in.
Jaxcam02 is offline   Reply With Quote
Old 11-16-2021, 02:05 PM   #8
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
As there test car its hard to be bias..
I like real replacement parts 80% of trufiber is real replacement parts the stuff that is to hard to make well not to hard but to bridle to install or remove are are made as covers. For instance the side skirts.. they had to be made as a cover and Anderson believes the same the clips will simply pull off or crack the carbon.
Comparison:
Dive planes: Anderson's last time I ck'd was only finished(wet) on 1 side trufiber finished on both
Zl1 1le bezel trufiber is an exact replica of the oem part Anderson's not sure
front spitter Trufiber is an exact replica and uses the oem hardware the Anderson seems a little bit of there own design
hoods or diffuser not available yet because I cant find a body shop that will aid in making a mold and brace. Why do this you will see that the anderson diffuser is to tight and pulls on your bumper causing unnecessary gaps. The part has to be made on the car not from a spare part like the rest. I run the Anderson diffuser because everything on the outside is carbon id rather have gaps then one mosiac part standing out.
anyhow here is my thread.
https://www.camaro6.com/forums/showthread.php?t=546716
trufiber is working on a 1le design spoiler
I'm also looking at making an insert for larger blowers like the LPE insert it will be better twill 2x2 vacuum infused vs 1 x 1 prepeg.
Old 11-16-2021, 02:20 PM   #9
DylansZLE
DylansZLE's Avatar
Comparison:
Any up-close pics of your side skirts? Thanks for your response
TPW - August 30
6000 November 1st
Old 11-16-2021, 02:28 PM   #10
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
only the link and these videos.. i can do more later if needed.
Old 11-17-2021, 04:38 AM   #11
1320it
Drives: Honda
Anderson is made in China and really poor quality. It is from the same company as Seibon
1320it is offline   Reply With Quote
Old 11-17-2021, 04:44 AM   #12
ZL1plumbin
Drives: ZL1 1LE on order
Is truefiber made in USA?
ZL1plumbin is offline   Reply With Quote
Old 11-17-2021, 04:59 AM   #13
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
No not usa a long time ago yes, they had problems w China quality they would send a beautiful sample part then make a big order and the order would be crap. There factory is in Vietnam I believe.
Old 11-17-2021, 07:37 PM   #14
DylansZLE
DylansZLE's Avatar
Have you gotten the carbon fiber grille from Anderson Comp?
TPW - August 30
6000 November 1st
