11-15-2021, 04:30 PM | #1 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
E50 and Pulley question
Anyone know what the max pulley size you can run with an E40-E50 blend of fuel on the stock fuel system? Currently I'm running a 9.45 lower with no ethanol. Is it possible to run E40-E50 with a 9.06 lower? I'm thinking if it's possible, the power should be close to the same but with less heat in the blower.
11-15-2021, 04:49 PM | #2 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I don’t know the direct answer that you are looking for but I believe you can run e60 at sea level with full bolt ons and no pulley with JMS booster. So I’d estimate e50ish with 1 step pulley down using the JMS. I believe that e40 is the most at sea level with full bolt ons and no pulley without a JMS. So I’d estimate probably e30 (10 points less) with 1 step pulley down, full bolt ons and no JMS. You wouldn’t know for sure without checking the tune to verify because every car is a little different and of course, altitude will play in also. Hopefully someone with your exact set up can confirm or correct me. |
11-15-2021, 05:19 PM | #3 | |
Drives: 2019 ZL1 Join Date: Mar 2019
E50 is possible with no pulley changes. If you look at teds flex fuel package its about 650rwhp or so with just flex fuel. Once you start adding boost I doubt you'll even be able to run 20-30%.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
11-15-2021, 05:21 PM | #4 |
About what I figured.
11-15-2021, 05:58 PM | #5 |
Based on what I have seen is you will need a LPE DI pump and JMS booster then you could run E40. IF you did FIC +30, LPE DI pump, JMS you could probably run E60 or higher @ .84 lambda.
my Brother's C7Z was limited to E40 when it was Bolt-on, ported blower w/ 2.3 upper, LPE DI pump and JMS booster. That is currently what I am limited to with the same fuel system making around 11psi peak when it's cold out. Temp plays a big factor. 85-95 degree day I can run E60. 60-80 degrees...E50. 45-55 degrees E40. Mainly because I see almost 1psi gain in boost per temp threshold drop. Ime the ability to run higher E content in the summer helps make up some power loss. When it gets cooler out you don't need as much E anyway. The colder denser air makes more power and less prone to knock.
2016 NFG 1SS A8
11-15-2021, 06:33 PM | #6 |
Yea, it sounds like any E is out of the question with any pulley setup other than stock.
11-15-2021, 07:08 PM | #7 | |
It’s pretty much like a give or take with E. Make the power on E, less boost or increase the boost and little to no E. Honestly it’s amazing just how much even a 10% increase of E has on demand for the fuel system. I dropped mine back down to 30-35% max. And I’ve got full 80psi and 3300 rail pressure at this content. I’ve probably still got a bit of room but now the injectors are the weakest link. I’m good with this one. My next build in the works I’m Pushing for 1100-1200 wheel.
11-16-2021, 03:19 AM | #8 | |
11-16-2021, 07:04 AM | #9 | |
Drives: 18 ZL1 Convertible Join Date: Jun 2019
11-16-2021, 07:12 AM | #10 |
Thanks for the feedback, are you running a ported blower too? 2.3 is a really mild, 8% increase in blower speed. A ported blower may push you over the fuel limit though. My blower is ported.
11-16-2021, 07:25 AM | #11 |
It’s not ported, I do agree with u, ur gonna be at the edge of the fuel limits. I had asked my tuner about the same thing… porting my blower and still using E. He didn’t think it would be possible.
11-16-2021, 07:40 AM | #12 | |
11-16-2021, 07:45 AM | #13 | |
Drives: HBM ZLE Join Date: Aug 2017
Can definitely feel a nice difference between standard e10 here and e25 |
11-16-2021, 07:47 AM | #14 | |
I have seen this since 2015 LT4 Came out, they are super knock limited on 93 octane Stock. Spinning the blower faster only makes the problem worse. The blower is pretty maxed out on stock ratio. I do a lot of testing and not looking at peak numbers but looking everywhere else. Part of the engine efficiency is being able to run a timing value the completes the burn in the closed chamber to do work on the piston and be able to do that for more than a 6 second dyno pull. I am not saying this to be a wise guy there is a message here. My car is faster with stock pulleys and cam (the JRE 125 Flex fuel road race package) then 90% of the cars we see with the book thrown at them with big dyno sheets. Too much focus on dyno numbers and not enough attention to how long you can stay at WOT with out losing power or engine destruction.. The question comes down to, Do you want a Fast Car or a Dyno Queen? Being able to burn higher quality fuel is a Win Win, you get both more power and Longer Engine Life under the most grueling situations. Feel free to pick this apart and ask a lot of questions, I'm always happy to get in on the party.
www.jannettyracing.com
