Old 11-14-2021, 07:10 PM   #1
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
RESULTS AT ECR WITH TRACKWING
Eagles Canyon Results with TRACKWING
Tried out a great new product today called TRACKWING www.trackwing.com. Basically it is a REMOVABLE big assed wing that is 71 inches wide and is TALLER than the roof of our cars. Look below for some pics I took of it yesterday PRIOR to me going to Eagles Canyon.
Anyway, I ran a 2.04.56 with the wing at Eagles Canyon today. Look below also for some pics of the Harry's LapTimer info on that run.
As near as I can calculate, the wing accounted for about a second reduction in lap time. The next time we go to ECR 2.02-2.03 range will be in the cards because by THAT time AMP will have the car modded have another 120 RWHP (heads and cam). It has 480 RWHP now with mods that have been done to the LT1 currently.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 11-14-2021, 07:26 PM   #2
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Thanks for sharing! So being removal, is it something you bought or rented?
No detectable challenges with imbalance in downforce front to rear?
Dabjbr is offline   Reply With Quote
Old 11-14-2021, 10:09 PM   #3
sr71bb
sr71bb's Avatar
The balance remained the same fortunately and I was still hitting 127 MPH on the back straight so I saw very little effect on the straightaway speed. I asked to rent the wing first just so I could see for myself that it was worthwhile.
What I DONT know about is whether Zl1 cannards and the larger chin spolier would be beneficial or not vs my smaller chin spoiler. I have been hesitant about that because I personally dont like the way they look.
On a side note, I am running E85 and in four 30 minute track sessions, I burned up 33 gallons of fuel so a little less than a half of tank of E85 per each 30 minute session. Burn rate of E85 is roughly 30 per cent faster than regular gasoline. I brought 3 5 gallon jugs with me and the car was full when I started. So I sort of made a rule for myself NOT to start a session with LESS than half a tank. I will say also that the gas tank baffles with the 6th GEN set up are MUCH better than they were with my 5th GEN. With my 5th GEN you could get fuel starvation due to fuel slosh if you had less than a 1/4 tank and a hard corner.
Retired Cars BELOW:
Old 11-15-2021, 02:17 AM   #4
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
It would have been interesting to have you do a session without it, then with it, back to back.
khcoaching is offline   Reply With Quote
Old 11-15-2021, 08:26 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
No signs of slippage or movement?
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 11-15-2021, 09:32 AM   #6
sr71bb
sr71bb's Avatar
No it actually has a manual pump up mechanism on each suction cup that helps it to maintain suction and a tethering system that if the wing SHOULD come off it would stay on top of the trunk and NOT hit the ground or the car behind you.
Retired Cars BELOW:
Old 11-15-2021, 11:29 AM   #7
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
just talking to my buddy about aero on 6th gens yesterday told him ive seen 3 places that make wings but no front splitters so hard pass on aero for me for now...
Old 11-15-2021, 12:37 PM   #8
Ummpwr
Drives: Honda S2000
I am very interested in this trackwing. Although I would want some front splitter or aero to compliment it. Anyone know if any front splitter or lip for a 18 SS1LE?
Ummpwr is offline   Reply With Quote
Old 11-15-2021, 12:47 PM   #9
kropscamaro16
apr makes one and aerosport concepts makes one but not a chassis mounted splitter
Old 11-16-2021, 07:59 AM   #10
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Front splitters are available at your local hardware store for about 40$. just need a marker, a saw and some mounting hardware.
That1guy_tim is offline   Reply With Quote
Old 11-16-2021, 10:24 AM   #11
kropscamaro16
haha this is true the only hard part is the mounting setup
Old 11-19-2021, 08:01 PM   #12
Ummpwr
Drives: Honda S2000
When you did the track day with the wing you said you were about 1sec faster. Did you remove the wing and re install it the same day to determine the difference that the wing accounted for?
Also did you see any dents in the rear trunk lid from the downforce?
Old 11-20-2021, 06:37 PM   #13
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
How did you run today and with the wing again?
RUQWIKR is offline   Reply With Quote
Old 11-20-2021, 06:51 PM   #14
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Everything I've ever heard about aero says that increased downforce from a wing (if effective) causes a wind resistance penalty, which decreases top speed on long straights. That's why underbody trays and diffusers became such a great solution (increased suction force - effectively downforce without a drag penalty).
If you aren't having your top speed affected (127 MPH is probably a high enough speed to see a significant drag effect from an effective wing, right?), I'd be doubtful that the wing is providing worthwhile downforce.
N Camarolina is offline   Reply With Quote
