Old 11-14-2021, 01:21 PM   #1
Village Idiot
Drives: 2019 Camaro SS
CTS-V2 brakes an upgrade over 4 piston Brembos?
I've been thinking about upgrading to the 1LE 6-piston Brembos but I saw ZZPerformance has a big brake kit for almost $1k less. It looks like they use the CTS-V2 calipers/rotors. They didn't have any testing data on them though which is odd.
Anyone use these or know if they're truly an upgrade over the 4-pistons? I'm assuming if they slowed that 4200lb boat then they'll do well on an SS, but it'd be nice to have some tests for $1700 brakes.
Village Idiot is offline   Reply With Quote
Old 11-15-2021, 10:29 AM   #2
Mountain
Mountain's Avatar
I can tell you that the calipers from the CTS-V and ATS-V do translate over to the Camaro stuff. What I mean is that the pistons, pad sizes, brake hoses, and other hardware are common. I think even the rotors fit correctly; however, I am not sure if you can actually bolt-on the CTS/ATS calipers to the Camaro mounting points.
Old 11-15-2021, 11:25 AM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
IIRC, those calipers are a common design with the ATS-V and SS 1LE Camaro. They should do fine on your SS as long as you're not adding significant power to drive on a road course.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 11-15-2021, 12:18 PM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have the same kit on my car and its awesome same calipers as 1le and same oem gm rotors i did the oem pads also since i was tracking my car if you have any questions let me know!
Old 11-15-2021, 02:52 PM   #5
Mountain
Mountain's Avatar
The 2009-2015 CTS-V has the 370mm/365mm setup, also the 5th Gen ZL1 setup. The 2016-2019 CTS-V has the 390mm/365mm setup, like the ZL1. The 2016-2019 ATS-V has the 370mm/339mm setup, like the SS 1LE. What setup did you install? Just curious.
Old 11-15-2021, 03:30 PM   #6
kropscamaro16
zzp bbk which uses a cts v2 caliper oem 1le rotor and oem gm pads
Old 11-16-2021, 09:49 PM   #7
Village Idiot
Car would never see a road course, I don't really have a specific reason for getting them I just want bigger brakes lol.
They're the same specs as the 1LE? interesting I don't know why ZZP didn't say that when I asked about them. When replacing pads are you using CTS-V pads or do the 1LE pads fit the rotors?
Old 11-17-2021, 11:09 AM   #8
kropscamaro16
i had the oem pads at first then switched to hawk dtc60 and i ordered 1le spec pads fit just fine
Old 12-03-2021, 11:28 AM   #9
ZZP_Tyler
ZZP_Tyler's Avatar
Drives: 2017 Camaro 2.0T RS
I developed and built the 6 piston kit and have had it on my car for 2+ years and over a dozen track days. It is 100% an upgrade over the 4 piston kit.
Like Krops said we use a CTS V-2 caliper and rotor combo. It's a 14.6" rotor, the new ZL1 1LE rotor is just a hair larger at 15". If you need replacement pads or rotors there's nothing special or machining needed, you can grab off the shelf options. The caliper is not a direct bolt on, the kit comes with a laser cut adapter plate. I've run the stock Brembo pads (Ferodo HP1000) as my track pad the last few years and then I use the Powerstop Z26 as my daily pad.
ZZP_Tyler is offline   Reply With Quote
