Old 11-12-2021, 07:28 PM   #1
Blueclyde
Drives: 2023 ZLE
ZLE Wheel/Tire Setup on Standard ZL1
I have a standard 18 ZL1 and recently picked up a set of ZLE wheels and tires.
I performed the mag ride strut modification to allow for front wheel clearance. I also performed the harness relocate on the left rear, which was simple.
I did not modify the top camber adjustment slot on the mag ride struts.
I did max out the front negative camber adjustment when I did the modification for wheel clearance.
I need to get it aligned to see where I’m at. How much negative camber can be achieved on the standard ZL1?
I do have Vorshlag camber plates on order (back order actually), but I’m not sure that I need them.
Blueclyde is offline   Reply With Quote
Old 11-13-2021, 08:09 AM   #2
SlikZL1
Drives: 2019 Camaro ZL1
About -1.7 up front and about -2.5 Rear. I think that’s plenty for 99.9% of people but I could be wrong.
Good luck on your setup ��
SlikZL1 is offline   Reply With Quote
Old 11-13-2021, 04:15 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I could go -2.0 front -1.6 rear no problem with the same setup on my '17 ZL1
Old 11-14-2021, 03:48 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Didn’t ZLEs share the same standard alignment as ZL1s? If so, it doesn’t seem to me there would be a reason there would be an issue after the necessary mechanical accommodations.
'20 ZL1 Black "Fury"
Old 11-15-2021, 10:52 PM   #5
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
About -2 in front is plenty. I haven't noticed less understeer with more camber (I am at around -3.2). Its about more even tire side to side wear (at the track). Lap times are more dependent on tires/tire compound. More camber also gets into reduced braking footprint, which matters at some tracks more than others. At COTA I still wear the insides faster because of the high speed straights ending in hair pins. I may reduce camber. For street use you'll just wear the inside and put lopsided wear on the bearings.
wakespeak is offline   Reply With Quote
Old 11-17-2021, 12:11 AM   #6
Blueclyde
Drives: 2023 ZLE
Thanks for the feedback guys!
Old 11-20-2021, 05:57 PM   #7
Blueclyde
Drives: 2023 ZLE
I was able to check my camber today with my new Smart Camber gauge. Again, ZLE wheels/tires installed on my standard ZL1. Modified the mag ride struts for wheel clearance, so no spacers used. Max’d out the negative camber. I’m sitting at -2.7 degrees on both sides. I think I will cancel the back ordered Vorshlag camber plates for now.
Old 11-20-2021, 08:06 PM   #8
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Well SLICKS if you ever decide to run them LOVE as much camber as you can give them on the front. I run -3.6 on front and -2.5 on rear and I run this on BOTH the street and track. EXCESSIVE toe in and Toe out is what will wear you tires out. I run almost NEUTRAL toe in toe out settings and I have NOT noticed as of yet any uneven wear on my street tires.
PRIOR to me getting the vorshlag plates my MAX setting on FRONT was roughly -2.0 degrees camber and about the same on the rear. To get the additional camber on the rear I am running SPL Toe Links with Eccentric Bolt lockout. This allows INCREASED adjustment in the camber PAST the -2.0 stock setting max. and eliminates the eccentric bolt that loses adjustment consistently when the suspension is taxed anyway. Part number is below.
https://www.splparts.com/products/ca...c-lockout.html
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 11-21-2021, 07:28 AM   #9
Blueclyde
Drives: 2023 ZLE
Good points. I just changed my wheel/tire set up so that would have been the time to go with slicks. I opted for the ZLE setup and will see how that goes. Thanks for the feedback though. I agree with you and may require camber plates in the future.
Old 12-02-2021, 06:25 PM   #10
Blueclyde
Drives: 2023 ZLE
Here are some photos of the ZLE wheel/tire on my standard ZL1. Camber and toe set to track. No poke up front. Will see how things go next spring before deciding on camber plates.
