Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Rear Side Panel Speakers
I'm wanting to put some bass blockers on the rear side speakers as they distort some at higher volumes. I know I can remove the rear seat and remove the panels to add the bass blocker to the speaker itself, but I'm curious if there's easier access to the speaker wiring elsewhere in the car? Between speaker and amp? At the amp?
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
I'm assuming you don't have the Bose system with the amp in the trunk, which would make life easy. I don't know if there is easy access to the speaker wiring in the other systems.
here are some pictures I found useful when removing the rear side panels. You can see where all the hidden fasteners are located. https://www.camaro6.com/forums/showthread.php?t=447779 if you end up doing this, the tricky bit is getting the very pointy rear tapered end to latch into the package tray when putting the thing back together. |
#3 | |
I definitely have that thread saved if I have to remove the panels, but hoping maybe there's easier access to wiring between panel and trunk.
