Old 11-03-2021, 01:50 PM   #1
FRANK121
FRANK121's Avatar
Drives: 2022 Camaro ZL1
ZL1 Burn Out
I just picked up a Black 2020 ZL1 Auto and finally got her broke in and have been trying to figure out this burn out procedure?
I can do the line lock procedure fine but I want to know how to leave
an intersection with tire smoking burn outs without the 5 minute setup procedure! ....lol
Is there a setting everyone has found that will allow smoking burnouts down the road?
I have tried turning off TC and putting it in Comp1, Comp2 and Race modes and it seems to spins for awhile then jerk then spin then jerk?
What is the secret?
Thanks!
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust.
665 Crank hp. est. and 660 Crank ft. lbs. est.
Never been Dynoed
FRANK121 is offline   Reply With Quote
Old 11-03-2021, 01:56 PM   #2
ZL1 C ya
ZL1 C ya's Avatar
Drives: 2018 ZL1 Camaro Convertible
Press the TC button twice to turn of the TC control and the Stabilatrack.
Welcome to the Club
ZL1 C ya is offline   Reply With Quote
Old 11-03-2021, 03:25 PM   #3
raptor5244
Drives: 2022 CT4-V Blackwing
If you turn off traction control only, (one press of the button) you will be able to keep spinning if you keep it pointed straight, however, if you start to get sideways a little too much to quickly Stabilitrack will cut power to prevent you from swinging the tail around and into a curb or group of people like a Mustang. If you disable both Stabilitrack and Traction Control it will not cut power as the rear end kicks out so be ready to react and correct. I suggest a wide open space to practice in.
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
Old 11-03-2021, 06:00 PM   #4
clg82
Drives: 2020 Camaro ZL1
Hold the TC button down for 10 seconds to turn everything off.....than have at it....but be careful....I wouldn't be doing any of this at a stoplight or intersection smh
Old 11-03-2021, 06:19 PM   #5
Dirtytim
Drives: 2021 Satin Steel ZL1
Hold the traction control button down for 10 seconds. It will turn everything off. What part of Missouri are you in?
Dirtytim is offline   Reply With Quote
Old 11-03-2021, 07:43 PM   #6
JacobC1983
JacobC1983's Avatar
Drives: 2019 ZL1
In for Missouri
JacobC1983 is offline   Reply With Quote
Old 11-03-2021, 08:12 PM   #7
Altered Carbon
Ghost Spawn
Altered Carbon's Avatar
Drives: Camaro
lul
Altered Carbon is offline   Reply With Quote
Old 11-04-2021, 07:38 AM   #8
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
also in for Missouri peeps
