![]() Drives: '21 M6 1SS 1LE Join Date: Aug 2021
short drive - oil temp?
kinda made an odd decision to trade my daily for an SS 1LE, and now as winter in Chicago arrives I'm seeing my errors
Basically my commute is 2 miles and the oil temp is not even cracking 100 degrees if I do drive right away. I'm left wondering if I should just baby it cold and avoid the extra heat cycles, or let it warm up. I do intend to keep this car for a long time both for track use and as a daily, otherwise id say f*** it and go. those of you with short commutes or who are know these cars super well, what are you doing? Any suggestions? |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Mines not a daily but I would suggest plugging in the block heater. It will make a difference for sure. The engine will have some temp right away opposed to being stone cold. Plus the defroster will start to work pretty much instantly
That’s if the car is equipped with a block heater. I would t be surprised if it is. I have to look at mine to see if I have one |
![]() Drives: Silverado RST 21, 3.0, Crew, Z71 Join Date: Jul 2021
I would recommend just warming it up for 30 seconds to a minute when starting, drive normally and shut it down when you get where you're going. At 2 miles, this is severe service and your maintenance will need to reflect this, but idling it warm won't change or help that and will just waste gas, add engine hours.
Of course, you can't run it hard until it's fully warmed up so this was a questionable choice for a daily as you note- although you can always take a nice 5-10 mile route to work it out on some days ![]() |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
It will be important to drive it a bit once fully warmed up, to get the condensation out of the crank case. So if no block heater option, then let the car idle for 2 mins before you drive or add some distance to your commute. Pull up the oil temp menu on the DIC Perfomance sub-menu (do not use coolant temp as a surrogate, as that heats up before the oil does), and make sure you drive a few minutes once the oil gets to 200 F before shutting it down.
The oil will handle things fine, but I suspect the algorithm will trigger a shorter change interval.
Block heater is a nice idea. No engine powered car is going to be happy with that short commute. The exhaust will have pooled water for sure. Maybe electric time? |
Perhaps it’s time to take the bus. Never in my life thought too short a drive in a sports car would be a problem
#7 |
#8 |
![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
I had the same problem however my drive wasn’t as short. If you can take a longer way or just drive your car around for 15 mins before heading to work I would do that. Someone mentioned biking to work. 2 miles is certainly close enough but that will **** when it snows or is super cold. If the budget allows, I would maybe get a <5k beater for going to work and parking in Chicago.
#9 | |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Now if I am going to be doing spirited driving, I let the car get completely up to temp. |
#10 |
![]() ![]() Drives: 2015commemorative vert 2SS Join Date: Oct 2013
My wife has a newer impala. She only drives about three miles one way to work everyday too. The oil life monitor in the car, was asking us to change the oil about every 4 months due to the fact she drove it so little.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
#11 |
![]() Drives: On Hiatus Join Date: Apr 2020
Could always stick on a wolverine oil pan heater.
I had one on my beater Subaru and the radiant heat would melt the snow off the hood. |
#12 |
![]() Drives: Chevy Camaro LT1, BMW M3 Join Date: Apr 2021
maybe use a lighter oil in the winter that can warm up quicker?
#13 |
![]() Drives: 2017 SS 1LE Join Date: Mar 2017
Uber time
#14 |
![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
