![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
WHERE DO YOU SET YOUR REV LIMITER AT?
Those of you with the Stage 2 cam/2650R blower setup (M6), where do you think your redline is? And, is it sketchy to wring it out that far? What about your rev limiter - do you use it?
Thanks
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Believe my cutoff is 7200. But shifts at 6800-6900, this is in an auto though. Pretty much all after market valve trains should be good for 6800-7k. Also really depends if your making anymore power past 6500 as well. Stage 2 and above should be.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
Moderator
Bingo. Same here.
Cam and 2650 should shift close to 7k.
Thanks, guys.
