Old 10-26-2021, 04:02 PM   #1
stocklt4
stocklt4's Avatar
Drives: 2017 Camaro ZL1 A10
Service Stabilitrak, Rear Axle – Need help isolating 17’ ZL1 voltage issues
Hey guys. Thought I’d make this thread to go over some issues I’ve been having and see if anyone else is in a similar boat or has some suggestions. My car is around 26k miles, FBO, cammed, ported blower with a smaller upper pulley. The car behaved perfectly fine for about 10k miles on these modifications. There’s also a TL;DR at the bottom of this post.
Problem Background:
A day or two after an alignment at a random tire shop I started having a “Service StabiliTrak” warning show up while driving. Soon it was extremely frequent and every time I drove. I would also occasionally get “service rear axle” or “service battery charging system” but those were rarer. I’ve even had my dash shut off twice. Currently, these warnings are very erratic and can alternate between not happening very often or happening a lot. When it’s occurring in higher frequency there is also an odd “wub-wub” noise preceding and following the warning. It sounds like some sort of hesitancy in the RPMs. I’ve recently discovered that the more I drive it the more it behaves just driving around town if I'm not hammering it. I don’t get to stretch the legs as often as I want to but if I do a WOT pull there is usually a barrage of warnings that follow until some time has passed or I turn off the car.
Timeline after issue begins:
My tuner checks the car and inspects all wires and finds nothing wrong. No codes show up. We decided to replace the alternator and the car drives fine for a few days before the problem returns.
“Battery charging system” warning increases in frequency and I replace the battery. That warning then reduced in frequency (probably just coincidence) but “Service StabiliTrak” continues to appear.
I take it to my tuner again and he spends a few days with it and is stumped
I take my Silverado in for service and mention my problems to my service advisor. He says they have a really good tech who works on highly modified Camaros/Corvettes and could try to leverage their GM resources.
I bring it to my dealer and they performed a “Global Reset”. They told me that it’s a dealer-only reset that can sometimes help solve these types of issues. Told me the issue is gone but when I get the car back it’s not.
Bring it in for an alignment just to see if that will do anything. Doesn’t help.
Present/Recent:
Take it in for the third time. This time they found codes (C0800, C0805, P0621, B1325) and some damaged wires:
“Technician came to conclusion of repairs needed of a 1 new connector at the generator and 2 new wire re-string due to damage from an outside influence that is not a common failure on circuit #234 and #25. They contacted GM technical assistance and they suggested to check both battery cable positive and ground result was negative battery cable being out of factory specification of .20 volts and actual measurement was 0.335 volts. They recommended to have the negative battery cable replaced.
Soon after the 2nd repair was completed the technician contacted GM to update the case with engineering due to still having P0621 and C0805 present set at 2,000 rpms. GM directed to inspect pulley system for modifications that can cause a high rpm output that’s outside of GM specifications due to those two trouble codes being present.
The technician founds 2 drive pulleys have been replace by a non-factory spec.” This is of course where they insert their *GM said no more repairs or assistance on this vehicle until it’s returned to stock* statement.
Lots to digest here so sorry for the info dump. My crank pulley is stock sized so I’m not sure how that would overdrive the alternator. My tuner stated that there is a voltage regulator and that it shouldn’t matter anyway.
TL;DR
When the engine reaches 2k rpm (corresponding DTCs P0621 and C0805) the ECM has a high voltage reading from the alternator. This triggers or seems to be triggering very frequent “Service StabiliTrak” warnings. It doesn’t always appear when the engine is around 2k rpm but aggressive driving usually brings about a condition where it begins to show these warnings frequently. Quite honestly this is ruining the car for me. Stumped and wondering if anyone has any advice.
stocklt4 is offline   Reply With Quote
Old 10-26-2021, 11:14 PM   #2
dbs1
Drives: 2017 ZL1
Mine did something similar last week when my son was driving and he used the aeroforce gauge to pull the codes (don't remember which ones) and then erased the codes.
Took it to my tuner shop as well as a Chevy dealer and they can't get it do replicate the problem or show a code. Service advisor did mention it sounded like it was dragging when starting and I may need a new battery. 2017 with 42,000 miles.
I'm thinking for piece of mind I'm going to stick a new battery in there. I'm hoping you figure it out because I'm thinking I may have a very similar issue.
dbs1 is offline   Reply With Quote
Old 10-27-2021, 11:51 AM   #3
stocklt4
stocklt4's Avatar
Had the issue of it not showing codes as well for a while. Possibly coincidentally, it started storing the codes soon after the global reset at the dealer.
2017 Camaro ZL1 A10 : Rotofab Big Gulp, Kooks 2 Inch LTHs, BTR Stage 2 Cam, Kong Ported Blower, Katech 103mm TB, Lethal Garage Flex Fuel Sensor, Elite Catch Can, DSX Auxillary Fuel Pump
2019 Silverado 1500 LT
Stock
Old 10-28-2021, 10:05 AM   #4
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert
There's a TSB on wire loom chafing on the 2017 ZL1. Has anyone checked into that? I don't remember the TSB number as I deleted my 2017documents when I traded it in.
Old and new, sharing space!
Tara Martin is offline   Reply With Quote
Old 11-04-2021, 12:32 PM   #5
Grinch_ZL1
have you by a chance checked your wiring harness inside the driver side wheel well? i had some similar issues that I tracked down to my tire eating through the fender liner and actually eating through the harness causing weird electrical issues like ur stating. worth a shot....
Grinch_ZL1 is offline   Reply With Quote
Old 11-04-2021, 01:13 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
See attached TSBs related to harness rub.
Old 11-05-2021, 01:44 PM   #7
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Is this front or rear wheel well? Starting to have similar issues
Old 11-05-2021, 04:24 PM   #8
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Driver rear.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 11-05-2021, 04:52 PM   #9
Evansa22
Evansa22's Avatar
Thanks
Old 11-06-2021, 11:19 PM   #10
dbs1
Drives: 2017 ZL1
My son was out driving mine this evening and let me know it hit freak out stage again and this time I told him NOT to erase codes or anything and get it to the shop. I'm going to have them start with the wiring of the jms voltage booster, then clean the connectors on the ported tb.
Then if they haven't found anything I'll have them check the wiring loom at drivers side rear, although when I first got it I relocated it slightly per info on the board but...it was running 315 Toyo rrr's then and since I've changed to 325's, so maybe?
Old 11-07-2021, 01:59 PM   #11
stocklt4
stocklt4's Avatar
Thank you for all the responses guys, seriously.
Going to be looking into this, thank you guys. Having my shop take a third pass on it and we will specifically look for any of these things.
Does anything seem to 'trigger' the freakout. After fixing my alternator connector it mostly is doing it when it's cold or when I'm flooring it or more than half throttle suddenly.
Stock
Old 11-08-2021, 08:51 PM   #12
SCCAForums
SCCAForums's Avatar
Drives: Chevrolet Camaro, Ford Mustang
If your drivers side wiring harness is not rubbed, this is a low battery. Trust me… I’ve experienced every fault known to man for a perfectly good battery being just “a little” low…
Happened again this past weekend at SEMA Optima ultimate street car… I was unable to disable traction control, and had a “service rear diff” error. Once we got battery charged… everything came back perfectly fine.
These cars put a tremendous strain on the electrical system, and the intelligent charging leaves much to be desired.
Best regards,
Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake
SCCAForums is offline   Reply With Quote
Old 11-09-2021, 11:29 AM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Is there an issue with the alternator or something? I feel like I've seen and read some people have issues with them on these cars.
One thing I have noticed is when I leave the car off the battery tender for more than a couple days, when I hook one back up to the battery, it registers the battery very low. Maybe the tender (an Optima) is exaggerating or whatever, but it seems to me the electrical load, even sitting, is HUGE. I just looked-up the alternator for these cars and it's 220-AMPS. It wasn't that long ago Escalades came with 140-amp alternators, and that was HUGE!!!
'20 ZL1 Black "Fury"
Old 11-10-2021, 02:47 AM   #14
stocklt4
stocklt4's Avatar
Alternator was replaced a while ago and it fixed it temporarily for 3 days. Also replaced a connector to it at the recommendation of GM very recently. That didn't fix it either. The current codes I'm getting are all alternator codes as well right now.
Stock
high voltage, rear axle, stabilitrak, zl1
