![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
Does LT1 need fueling help with E85?
Anyone hear of the LT1 needing some kind of supplemental fueling to run E85?
On a stock motor. I'm being told to run a fuel pump voltage booster. When I mentioned I hadn't heard of this being an issue, I was told every LT1 needs it when they start running E85.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
i'm pushing almost 1000 wheel and don't have one, when NA H/C i was running full e85 without one.. just depends on who tunes / works on your car.
then again with my boosted setup now is 50/50 e85 and 93 as well as meth
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i typically see an ethanol content between 75-80 and i have no issues. bolt on car.
I'm on E85 with my C7 and have long tubes/offroad pipes, Mamo ported Msd, Lt5 TB and I have no issues with the low side and thats what you need to look at when going to E plus the injector pulse width. I run anywhere between E65 and E85 depending on the fuel I find.
#5 | |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
You don't need to touch the fuel system on E85 when NA until you get around 600whp. Upgrading to the LT4 fuel system high/low will get to about 730-750whp on full pump E.
This is based on Naturally Aspirated combos not Forced Induction.
#7 |
Thanks for the replies, folks.
I am already tuned for E85, but was looking at switching to another tuner who is very active on this board. He is the one that said all E85 builds need a voltage booster. Caught me off guard.
2017 HBM SS 1LE
#8 |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Cant say for sure, but its prob being recommended for safety, not necessity.
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Agree with those other guys, using just bolt-ons NA, the stock Camaro SS Coupe fuel system can handle full E85, many people have done so. Plus, your 1LE model already has the ZL1 low side pump (stronger) from the factory, so I seriously doubt that you need a voltage booster on your low side. What is your fuel pressure doing in the logs now?
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
#11 |
![]() Drives: 2017 Camaro SS Join Date: Jun 2021
GPI remote tuned my camaro for E. Couldn’t have been easier. Responded in less than 24 hrs with each update file. Deff look into them if your looking for a new tuner.
