![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Question for those familiar with tuning with HP tuners
What is the norm for KR Sensors section and Misfire section? Do most of you leave them stock, slight bumps? Or big bumps in settings to desensitize?
IMO I would think they get adjusted if needed, but not desensitize just cause you don't want to see anything in the log?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
![]() ![]() Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Well, i dont have great info, so wasnt going to chime in, but since its been a few days and no responses, ill add my 2 cents. The trick is knowing if and when you are getting real knock. Only sure way is on a dyno... and not even necessarily then, so its probably experience more than anything.
For me, i did an eth conversion, and was in a fuel and timing combo that absolutely no way should have any knock... and it was showing up. So it was just a judgement call. I raised the knock thresh 10% at a time until it was minimal KR. I think my my knock sensor thresh is around 4.8 or something currently. Ive seen them in the 6's on some tunes. Long story short, i dont think theres a standard value you can just safely apply without considering the whole picture. I would say stock sensors are tuned to be very sensitive and could prob be raised by 10% with low risk, but beyond that i cant say. 10% isnt much but helped quiet some of the KR noise. My opinion is better safe than sorry. |
#3 | |
#4 | |
Moderator
![]() Drives: 2018 ZL1 Join Date: Oct 2019
I wouldnt touch the knock sensor sensitivity. If you are seeing knock then you need to see if its false knock or not before adjusting the sensitivity.
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
![]() Drives: 2017 Camaro RS l4 turbo Join Date: Dec 2013
I have the HP at stock setting, and still get small knock readings on WOT, I think they're just false readings since my lamda reading is around .85 with E-85 and one step colder plugs
