Old 10-18-2021, 05:57 PM   #1
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Kooks Headers and Plug Wire Fitment
So I am considering a set of Kooks 1 7/8 (or possibly the 2" headers as they are about $100 cheaper) and cats for my 2017 Camaro SS.
Are there any spark plug wire fitment problems with wires contacting the headers?
I would likely get some insulating sheaths for the wires but it is always better if there is no contact.
Thanks.
Spaceme1117 is offline   Reply With Quote
Old 10-18-2021, 07:17 PM   #2
Puddin
Yep better get some bendable booted plugs and put some heat socks on them
Old 10-18-2021, 07:25 PM   #3
Trochoidal
Drives: 2017 Camaro 2SS A8
2” here and I also opted for 45° wires and socks.
Old 10-18-2021, 09:13 PM   #4
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Taylor wires. DEI fire sleeves
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 10-18-2021, 09:53 PM   #5
Thanks.
Kooks 1 7/8" here with NGK 6510 plugs and MSD wires, no contact and plenty of clearance.
Old 10-19-2021, 04:18 AM   #6
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
No issues. Stock wires and no heat boots. Working fine. Just check wiring loom under coolant tank, you might need a sleeve on it
Timbo-1LE is offline   Reply With Quote
Old 11-28-2021, 07:28 AM   #7
Motor Fast
Thanks.
I'm running KOOKs with stock wires and have no problem. I'd recommend the boots like Trochoidal posted; I got a set from West Coast Corvettes.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette | 2012 Corvette ZR1 Inferno Orange with PDE | 2016 Corvette Z06 C7.R | 2018 Yenko Camaro
Motor Fast is offline   Reply With Quote
Old 11-28-2021, 09:55 AM   #8
Spaceme1117
Thanks.
I installed the headers a few weeks ago. None of the stock plug wires are touching.
I made sure to wrap the wire harness under the coolant tank with head shielding and secure it away from the headers.
Old 11-28-2021, 04:30 PM   #9
SSUNDVL
Drives: 2016 Camaro SS
I run MSD wires with no boots but probably should have boots, nonetheless wires have been good for 30k miles and plenty of room.
SSUNDVL is offline   Reply With Quote
Old 11-28-2021, 05:54 PM   #10
laynlo15
Drives: 2022 Lt1 A10
I use the Speed Engineering 2" longer wires that they make in house. They allow you to have enough room to move them around and keep them away from the headers without using the boot shields that I have also used in the past.
Old 11-30-2021, 09:47 PM   #11
Nightfire
Drives: 2018 Camaro 2SS
Not to Hijack the post but Just installed 2" Kooks and notice that the header just touches the brake line hold clip. Anyone else have this issue and if so what did you do to resolve it (Heat shield tape)?
Nightfire is offline   Reply With Quote
