Old 10-16-2021, 09:09 AM   #1
ohyeahjay
ohyeahjay's Avatar
Drives: 2022 Camaro LT1
Timing being pulled when spraying
When spraying 100 shot, 15 degrees of timing is being pulled. Running stock tune, LT2 intake, GM cold air intake, logging with HP Tuners. Is this normal to see this much timing being pulled or is torque management kicking in?
2024 Shark Skin Metallic LT1 On order
2022 Equinox LT
ohyeahjay is offline   Reply With Quote
Old 10-16-2021, 10:51 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
That is too much timing being pulled for a 100shot.
Old 10-16-2021, 06:18 PM   #3
ohyeahjay
ohyeahjay's Avatar
And it does it once the nitrious kicks in
2022 Equinox LT
Old 10-16-2021, 06:39 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
If you datalog the right channels in VCM Scanner it’ll tell you what source is pulling the timing.
Old 10-17-2021, 08:57 AM   #5
ohyeahjay
ohyeahjay's Avatar
I will pass the information along. Here is the video, 3:41 shows the data log.
2022 Equinox LT
Old 10-17-2021, 09:30 AM   #6
KingLT1
KingLT1's Avatar
How are you pulling timing for the Nitrous? It looks to me like the ECU is defaulting to the low octane spark table due to the base advance number being so low. Try copying the High octane table to the low octane table.
Once you get that sorted then you will likely need to up your peak torque limits and driver demand table to keep the throttle from closing.
Old 10-19-2021, 05:21 PM   #7
ohyeahjay
ohyeahjay's Avatar
what would make it (or what sensor) would make it revert back to the low octane table.
2022 Equinox LT
Old 10-19-2021, 07:37 PM   #8
KingLT1
KingLT1's Avatar
Usually knock sensors...also I know on older GM ECU's they would default to low octane tables if the MAF was disabled running open loop SD. but without more details, looking at the tune, and seeing how the system is setup to pull timing on activation all I can do is speculate.
