Old 10-13-2021, 03:37 PM   #1
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
Looking for more sound on my ZLE
Looking for input ….
Background- had a M6 ZLE with borla Axel back and it was exactly what I wanted. I sold the M6 and moved the Borla over to my A10 thinking I would get the same sound. Unfortunately not. On the A10 below 4K it’s very tame - not stock tame but not to my liking, not like the pops and burble that I got with the M6. Now, I did use a clamp on this install - and wonder if small air gaps might be there and cause loss of sound?
In any case - what do you recommend I do next to add more sound at idle or below 3k? I don’t want to do headers or remove secondary cats…any other options?
Thanks all
Zl1+911 is offline   Reply With Quote
Old 10-13-2021, 05:25 PM   #2
clg82
Drives: 2020 Camaro ZL1
I have the Borla catback system specifically the S-Type, and I get pops and burbles when decelerating from higher rpms or manually shifting. With my valves completely open utilizing my M2W switch it isn't tame at all for me. Maybe it's the Axleback that is your issues?
Old 10-13-2021, 05:26 PM   #3
DangerZL1
Drives: 2023 Black ZL1 Auto
The ATAK would be more to your liking. From what I’ve read, the sport is a better match if you decide to add headers later. Maybe a set of headers would give you the sound you’re looking for.
Old 10-13-2021, 05:43 PM   #4
sspddmn
sspddmn's Avatar
Drives: 2018 ZL1 1LE and 1991 Z28
Buddy of mine has a 2017 ZL1 A10. All he has is a rotofab and muffler delete using magnaflow axel back system and his car is as loud if not louder than mine and i have awe track edition cat back with link pipes (secondary cat delete). His system still has the crushed part of the exhaust before the axel too. Don't ask me how but its loud AF and it sounds really really good. No rasp. Just a mean loud rumble and growl. I should have gone that route and saved myself $800 lol
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2022 Audi E-tron SUV (wife's car) // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
Old 10-13-2021, 06:50 PM   #5
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Did he go with the Race Series (no mufflers or valves) or the Competition Series (mufflers and valves)?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 10-13-2021, 07:21 PM   #6
sspddmn
sspddmn's Avatar
No muffler or valves. They are the ones here.
Old 10-13-2021, 07:46 PM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
Thanks all
Mine has awesome sound from the components you don't want, so it's irrelevant
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-13-2021, 08:14 PM   #8
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
OP, it's a lot easier to make fun noise with a manual than with the auto. It's literally the only thing that bugged me about my A10 ZL1 before I sold it. I had Corsa Xtreme+ and it was beautifully loud on partial or full throttle, cold start, revs etc. but you do not get the hard decel ability so it doesn't pop. Letting off the gas, in gear, in manual, with the A10 to decel does not burble and pop like an M6 car will. I've driven both back to back. Also, due to the nature of the car, you cannot "aggressively" accelerate while not going speed limit shattering speeds in the A10 because it shifts right now and keep going. With a manual you can wind out a gear a little bit at say 75% throttle, shift slowly and kinda roll into the next gear. It sounds awesome but you aren't doing 120 MPH. With the A10 you either have to let off or get a lawyer.
I would get the Borla X-Pipe with secondary cat deletion. They make one. May have to call them to get it ala carte though. That'll add a little volume and a little more pop.
Old 10-13-2021, 08:25 PM   #9
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
Drives: 2017 ZL1 A10
My thoughts exactly.
The sound is out there.... you just have to find it.
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
'10 2SS/RS M6 455rwhp - sold
'13 ZL1 M6 720rwhp - sold
'17 ZL1 A10 930rwhp - Katech Built
ZLAV1N is offline   Reply With Quote
Old 10-13-2021, 10:28 PM   #10
serper3
serper3's Avatar
Drives: 2018 Camaro ZL1 1LE
I understand the A10 won't burble and pop on decel as much, but if you put it in manual mode, can't you hold gears while accelerating kind of the same way as in a manual?
serper3 is offline   Reply With Quote
Old 10-14-2021, 12:14 AM   #11
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
You can tune for those silly burbles and popping if you want.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 10-14-2021, 01:15 AM   #12
Zl1+911
Thanks everyone…appreciate the inputs. Don’t want to do headers and tune for warranty right now. I think I’ll look into the magnaflow option…
