10-08-2021, 05:34 PM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Higher octane without tune
Like the title says, living in Cali we’re limited to 91 at the pump, anyone know a way to get a higher octane while still staying on the stock tune? Any benefit to that at all? Thanks for any help.
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
10-08-2021, 06:01 PM | #2 |
Thank you Al Oppenheiser!
Race gas.
10-08-2021, 06:05 PM | #3 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Boostane..doesn't necessarily add hp, but helps keep the 650 you were given by avoiding timing being pulled.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
10-08-2021, 07:28 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
Try some octane booster from the auto parts store.
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
10-08-2021, 07:41 PM | #5 |
There's no benefit of higher octane with a stock tune. Cali has a million Camaros running stock tune/gas.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
10-08-2021, 08:17 PM | #6 |
Drives: Bmw M3 Join Date: Sep 2021
The performance supplement guide states to run 100 octane in temps above 86 deg. I imagine to prevent the engine from pulling timing.
"Consider using 100 octane unleaded gasoline if the air temperature is above 30 °C (86 °F) at a track event " Last edited by Redline10000; 10-08-2021 at 08:34 PM. |
10-08-2021, 09:03 PM | #7 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
10-08-2021, 09:17 PM | #8 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Its going to knock on 91, esp when warmer out. Adding torco or boostane will help that. Just be forwarned about the orange tailpipes and plugs if you use it.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
10-08-2021, 09:33 PM | #9 |
10-09-2021, 12:44 AM | #10 |
Hmm interesting conversation going on here, so an additive and possibly race gas would help bring the octane up but no significant HP increase. SO what is the benefit of upping the octane than?
10-09-2021, 02:21 AM | #11 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
The benefit is, it will add some power over the 91. Because the higher octane will let your car come out of the low timing table (91oct.) And use its high octane timing table, that is already programmed in your ecu. Basically higher octane will let you use the max available timing given from the factory.
Just try the Boostane, or Torco give it some time to adjust, and see if it's worth it to you.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 Last edited by swisstyphoon; 10-09-2021 at 02:52 AM. |
10-10-2021, 10:31 AM | #12 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Do not do this! You need a race fuel concentrate. I use the Race Gas brand: http://race-gas.com/ purchased thru Summit.
10-10-2021, 10:33 AM | #13 | |
@zle_blackwing
I disagree. The factory #s are with 93. The owner's manual states that using 91 will decrease performance and gas mileage.
10-10-2021, 11:42 AM | #14 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Boosting the octane level in your stock vehicle from 91 to 93 or above will allow you to maximize the factory horsepower level. It will not technically “add” horsepower.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
