![]() Drives: ZLI 1LE; 992 S; GLE 450, Denali HD Join Date: Sep 2019
Frayed Wiring Harness - Driver rear wheel well
I was getting my car ready for what could be my last track weekend with the car. I am running 345 / 19 proxes in the rear for the first time so I decided to relocate the wiring harness just in case. I never had any rubbing issues with the 3R's or my 18" track wheel but figured better safe than sorry.
I am embarassed to say that I screwed up the relocation process. I didn't check my work, I actually moved the wiring harness in harms way. I apparently placed the wiring harness were is was rubbing the side of the inner tire shoulder. Dumb, dumb, dumb. Drove the car to get a full tank of 100 Octane and filled up a couple of containers ready to hit the track this weekend. On the drive home, bam, car sputtered like it ran out of gas. As I pushed the car into a parking lot, my first thought was that I must have screwed up the harness. After inpection, my fears confirmed - dumb, dumb, dumb. Two wires are frayed, both appear to be black with a green stripe. I fixed harness, spliced one back with a connetctor and retaped the other as it was just the jacket that was damaged. I checked the fuses, nothing blew. But car still not starting. I have a JMS fuel pump boosted, the green light is on - thoughht I may have fried the booster so bypassed it, still no luck. No power supplied to the fuel pump. Anyone have any ideas on what I should check? Is there a reset procedure that I should be doing or another set of fuses to inspect? Any advise from the platform experts out there appreciated. Sincerely; Dumb ZLE owner! |
![]() Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
sorry to hear man.....it happens. we have all done things like this....
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Check the fuses again
