Old 10-06-2021, 06:43 PM   #1
Baddawg53
Drives: 17 hyper blue 2SS M6
LT1 clean side separator delete
The factory clean side separator connects the two valve covers, and has a hose to the air intake tube. I'm curious the ramifications of removing the hose entirely from the intake hose, and calling the middle port on the separator. The hoses from the valve covers would remain in place.
I have the elite engineering catch can which ties into the intake pipe. I'm still getting quite a bit of oil in the intake and it's coming from the sump in the air intake hose, which is now connected to the elite engineering oil fill cap. This is their clean side system, I want to get rid of that, and replace the intake tube with something custom.
Seeing as the catch can connecting to the intake tube is supposed to make the catch can work 100% of the time, how important is that clean side tube?
Baddawg53 is offline   Reply With Quote
Old 10-06-2021, 08:38 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
The clean-side feeds fresh air to the engine and PCV system. Removing the line and plugging the box will essentially disable the PCV system. I wouldn’t recommend that you do that.
Not that it matters but it looks like you have a Mishimoto can rather than an Elite can. If you think you’re getting excessive oil in the intake then maybe check the can to see if it is working correctly. Or contact Mishimoto to see if they have any recommendations.
Mark114 is online now   Reply With Quote
Old 10-06-2021, 09:13 PM   #3
Baddawg53
Shoulda mentioned it, that's not my car. Just a photo I found online.
Old 10-06-2021, 09:33 PM   #4
Baddawg53
Thanks, this is the information I am looking for. How this system works. The oil was not coming from the catch can, it was in that sump in the intake tube connected to the clean side. The elite engineering system replaces the oil fill cap, and attaches the new cap to the sump on the intake tube. Obviously now that you say that, it's where the engine draws the fresh air in from. Something has to be wrong then if it's pushing oil into that sump.
I know at idle there is a vacuum in the crankcase, the catch can is supposed to make the PVC system work at wide open throttle too, but maybe there's an issue there somewhere.
