Old 10-04-2021, 03:03 PM   #1
pavetim
Drives: firebird
Larger oil filter?
Anybody know any larger oil filters we can use for my 2017 SS. I have been usimg the wix xp but seems kind of small for a 6.2l
pavetim is offline   Reply With Quote
Old 10-04-2021, 03:08 PM   #2
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
I mean, you could use something taller but I don't see the point myself.
A taller filter could be more vulnerable to damage since our car already sits low-ish. Not a problem on a truck.
I think a lot of guys here track with the stock PF64 oil filter without trouble.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 10-04-2021, 03:49 PM   #3
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
I am currently using a PF63E. Same specifications as a PF64, but has a longer cannister than the PF64. Note that it hangs down a bit lower than the stock filter but not too low as you can see in the pictures.
However, at my next oil change I plan to change to the WIX 57502xp. Again, same specifications as the PF64 with a longer cannister, but not as long as the PF63E.
--KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 10-04-2021, 05:48 PM   #4
SSUNDVL
Drives: 2016 Camaro SS
Doesnt gm recommend pf64? for an oil filter why would you want something different?
SSUNDVL is offline   Reply With Quote
Old 10-05-2021, 12:18 PM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
They think it's longer means more filter media and there is thus some advantage to it, it's all in your head though. They think they sounds kool at QuikTrip on a Saturday nite talking about their filter prowess.
Old 10-05-2021, 01:56 PM   #6
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Bigger, higher capacity oil filter won’t hurt anything but you really are not gaining anything either.
Spaceme1117 is offline   Reply With Quote
