Old 10-02-2021, 06:01 AM   #1
Jordie
Drives: 2016 ss manmission
Fan going on full power after car is shut off
So my car is from 2016 ss manual. Have around 50k miles it has happened 3 times already. First time night was cool and it fix after itself then after 3 months same thing happened and it fixed by itself after 2 days. Now it happened again just after one day that the second time occurred. So the issues is, while I’m driving the engine temperature needle drops all the way to the bottom when it should be around 200, and the rev match deactivate by itself and the ac stop blowing cold air, then if I turn off the car the engine fan keeps going on at full power after I turn the car off for at least 5 minutes. Any recommendations as to what might be causing this. Just letting you guys know this hasn’t happened in hot days or hours. If I take it to the dealer what should I spect. Thanks guys.
Jordie is offline   Reply With Quote
Old 10-02-2021, 09:03 AM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Look at MAF connector and MAF sensor. If the temperature signal from there is lost this can occur.
Old 10-02-2021, 10:18 AM   #3
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: Stock 2016 Camaro V6
Same issue. Turned out to be the thermostat. Had it replaced and hasn't happened since.
Here in Monterey, CA dealer charged about $500 to replace. Might be cheaper in Florida.
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 10-02-2021, 11:10 AM   #4
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
This happened to my car after I added a Rotofab intake. Turned out that the clamps that came with the kit were not sealing the intake connections very well. Upgraded the clamps and no problems anymore.
Spaceme1117 is offline   Reply With Quote
Old 10-02-2021, 12:18 PM   #5
Yang N’ Bang
17’ Hyper Blue 2SS
Yang N’ Bang's Avatar
Drives: 17’ Camaro 2SS
Had this same issue a month or so ago, turned out to be the coolant temp sensor.
Yang N’ Bang is offline   Reply With Quote
Old 10-02-2021, 03:56 PM   #6
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
This is the most likely problem.
Warrior102 is offline   Reply With Quote
Old 10-03-2021, 12:10 AM   #7
TCCamaro
Drives: 2016 Camaro 1LT RS V6
Thumbs up
I had this exact same issue on my 2016 Camaro, I ended up disconnecting the battery in the trunk, letting the car sit for 10 minutes, reconnecting it, and never had an issue again, it was a one time thing, I would try this first before buying and replacing a thermostat
TCCamaro is offline   Reply With Quote
Old 10-03-2021, 12:35 AM   #8
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Try the battery disconnect but if it comes back then replace the thermostat. Then the coolant sensor.
So many of these cars had the same issue early years. I still have the issue, originally only wanted to change coolant sensor but on the v6 it’s very difficult to reach. Bought a thermostat as well so I’ll replace both when I actually tear the IM off again
2016 1LT v6
- Totaled
Happiness: Infinite
Old 10-05-2021, 09:43 AM   #9
wal-dog
Drives: 2016 Garnet Red 1SS
I did coolant temp sensor first. Didn't fix. Did thermostat next and now it is fixed. I would just do both at the same time.
wal-dog is offline   Reply With Quote
manual, manual tranmission, rev match off
