Old 10-01-2021, 07:35 PM   #1
LT1ornothing
Drives: 2020 LT1 M6
305/50/R20 Nitto drag radial
Wanted to ask if anyone has ran this drag radial, specifically asking about the sidewall height, advantages/disadvantages etc. I understand this tire has a lower speed rating than the 30 and 35 sidewalls also offered in this height and width. Anyone with any feedback on this 50 sidewall version would be highly appreciated.
Old 10-02-2021, 03:58 AM   #2
STALKER_174
Drives: 2018 Camaro 2SS Aussie version
Looking at the size its a full 15% larger diameter than the normal tyre and with a heap more sidewall (57%). I dont think it would even fit inside the guards, but if you measured your current tyre and doubled the sidewall height it might give you an idea of where it will sit
STALKER_174 is offline   Reply With Quote
Old 10-02-2021, 08:16 AM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Way too tall, will never fit. Even 305/35/20 is a close call. Unless you’re talking about a much smaller rim…?
Old 10-02-2021, 08:53 AM   #4
LT1ornothing
Drives: 2020 LT1 M6
Yes, apparently it mounts on an 8.5" rim, I am sure it would balloon a bit, but nittos tend to run small compared to other tires. I remember my nitto 315/35r17 555r was barely larger than the 275/35r17 non drag radial I was replacing back in the day.
Old 10-02-2021, 11:05 AM   #5
s346k
s346k's Avatar
Drives: like an old lady
305/50 is a truck tire. terrible choice for a tire, especially for an m6 car.
Old 10-02-2021, 11:31 AM   #6
LT1ornothing
Drives: 2020 LT1 M6
I just figured the meatier sidewall would provide a better launch on a lighter car. I don't road course the car, just looking at options to cut at least a 1.7 60 ft on the strip AND the street. Not looking to run mickey et on the street or anything stickier that won't last at all.
Old 10-02-2021, 11:59 AM   #7
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Is today April fools day? That’s crazy big.
Do something smaller in diameter that will still fit over the brakes…. 18 (maybe even 17) wheels and drag tires. I’m certain you can find other setups on the site.
Dabjbr is offline   Reply With Quote
Old 10-02-2021, 12:46 PM   #8
LT1ornothing
Drives: 2020 LT1 M6
I was just looking to toss something sticky on the factory 20×8.5" wheels, this seemed to fit the bill. I guess I might be the first to try it out. Many have had good results on 20" drag radials with the lesser sidewall heights available.
Also, my rear brakes are much smaller than yours, I have an LT1.
Old 10-02-2021, 02:54 PM   #9
Joshinator99
Moderator
Yes, apparently it mounts on an 8.5" rim, I am sure it would ballon a bit, but nittos tend to run small compared to other tires. I remember my nitto 315/35r17 555r was barely larger than the 275/35r17 non drag radial I was replacing back in the day.
No way. It’s borderline on a 9.5” stock SS rear wheel.
Old 10-02-2021, 03:38 PM   #10
LT1ornothing
Drives: 2020 LT1 M6
Well, the tire is approved by nitto for a 20×8.5 wheel. I would like to see if it would mount and not rub. They are a tad heavier, haha.
Old 10-02-2021, 03:48 PM   #11
Trochoidal
This will give you an idea of what the clearance is on a 305/45-17. Also look at the comparison of diameters. I’m all for trying something new/different but I don’t know how you could fit a 32” tire on the rear unless it tucks.
Old 10-02-2021, 03:55 PM   #12
LT1ornothing
Drives: 2020 LT1 M6
Looks like it will definitely have a nice rake if it will even mount without rubbing. It was a shot in the dark. I'm just gonna keep a look out for matching SS rears and go with a 275/35r20 nitto drag radial later down the road.
Old 10-02-2021, 04:02 PM   #13
Trochoidal
I’m in the market for a DR setup too. I’ll keep an eye on this thread for updates.
Old 10-02-2021, 10:07 PM   #14
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The 305/50/20 is 32" tall and weighs 44lbs. It will cause Stabilitrak to freak out unless you put a 31" tall tire on the front. You have to keep the front and rear tire height within 1".
