Old 10-01-2021, 04:50 PM   #1
IneedAZ
IneedAZ's Avatar
Added e and exceeded my hp goal
I would have to think the numbers would have been higher if my MAT numbers weren't so high. Think my final dyno run had MAT Temps in the 160s, but still yielded 848hp/792tq on e50. On a normal basis I will keep it at e30 or e40. This is with stock high side. Think he said inj pw was 6.2 or 6.3 on the e50. My guess at e30 or e40 I will be 6 or less. Now I can phase out my boostane. Today the car didn't have any added, but I still have nearly 4 gallons left to use up, so will add some over the next several months. The one thing I forgot to ask him was how well did the low side pressure hold up.
Old 10-01-2021, 05:01 PM   #2
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Nice, so only cam upgraded to drive pump more?
Would love to hear a sound clip
Old 10-01-2021, 05:28 PM   #3
IneedAZ
IneedAZ's Avatar
38% cam, dsx aux low side, and Lingenfelter High flow check valve.
Old 10-01-2021, 05:57 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Nice gainz!!
His tuner targets .90 lambda...so keep that in mind. @ .82 like many tuners target he wouldn't be able to run any E on his setup.
Old 10-01-2021, 06:34 PM   #5
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Nice gains but i dont know anyone who tunes lt4's this lean or has injector pulse width that high. 6.2, 6.3 inj pw is very high.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 10-01-2021, 06:44 PM   #6
IneedAZ
IneedAZ's Avatar
Nice gainz!!
something I noticed, his gauges while tuning are set to afr rather than Lambda. He likes to run LT4s at 13:1. On the street I was looking at my gauge in afr and it was 12.7 to 13.3 ..so I guess 13.0 avg. For me, I have been trying to use Lambda now.
Old 10-01-2021, 06:47 PM   #7
IneedAZ
IneedAZ's Avatar
On 93 my pw was 5.0. Keep in mind that the 6.2/3 was at 50% mix which I don't plan to run. I will do a log at both e30 and e40.
Old 10-01-2021, 06:52 PM   #8
IneedAZ
IneedAZ's Avatar
Curious to what afr/ lambda Pray uses. When I looked at some dyno runs on YouTube it looked as he was between 12.7 and 13.0
Old 10-01-2021, 06:57 PM   #9
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed. Playing with fire IMO.
Old 10-01-2021, 07:08 PM   #10
IneedAZ
IneedAZ's Avatar
Well..he has tuned many at 13 across the country..unfortunately I haven't seen any failure rates published by his tuning or anyone else for that matter that shows it was a lean failure. If you have any and they show what afr or lambda it was at on a LT4 let me know. Many online dyno videos don't show the afr/ lambda at all.
Old 10-01-2021, 07:33 PM   #11
IneedAZ
IneedAZ's Avatar
Wonder if this is still true as I found this written in 2017:
Dynojet software uses 14.7:1 air fuel ratio to determine Lambda 1.00. If the fuel has oxygen in it as does e10 (3.5%), then you must factor in .959, which brings a 13:1 air fuel ratio down to 12.5:1.
Old 10-01-2021, 07:41 PM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
Sounds good. We'll tune mine on E85 over the next 2 weeks.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-01-2021, 08:08 PM   #13
IneedAZ
IneedAZ's Avatar
How much e do u think u will run? Even though he tuned mine at e50 I only plan to run e30 most of the time. I plan to do a log once I get down to e30.
Old 10-01-2021, 08:21 PM   #14
Evansa22
Evansa22's Avatar
Nice gainz!!
Oh wow, ya mine says he goes for .80-.82. Makes sense, I had e37% and pw shot thru the roof for a second. Now I'm at 20-25% and the car is happy
