Old 10-01-2021, 08:36 AM   #1
FoundNemo
Drives: 2019 ZL1
Header collector bolts loosening constantly
Anyone have some tips/tricks for header bolts near the collector (CSP) loosening frequently? Lock washers are in use and some loctite blue but no dice, still seems to loosen pretty quickly over time.
FoundNemo is offline   Reply With Quote
Old 10-01-2021, 09:46 AM   #2
Vigilante375
Drives: 2018 Camaro ZL1
Blue loctite, or anything like it, will just melt away with the temps.
I think most people use anti size, torque to the correct spec and are good to go.
I'm not sure what the torque spec is but what are torque are you seeing them to?
Old 10-01-2021, 10:09 AM   #3
EV2DEMON
Drives: 2004 Z06, 2017 1LE
Get rid of the lock washers and use thick, flat washers.
EV2DEMON is offline   Reply With Quote
Old 10-01-2021, 10:38 AM   #4
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
What bolts are you using? If using the stainless bolts that came with them or other stainless bolts, no Good. Use grade 8 2 1/2” bolts with flat and lock washer, they won’t come loose. I went over this in another post.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 10-01-2021, 10:46 AM   #5
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Get a set of Percy's multi layer aluminum gaskets. I have them om several cars, no leaks an no loose bolts.
overdriv is offline   Reply With Quote
Old 10-01-2021, 12:21 PM   #6
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
You happen to know the diameter of the bolts?
Old 10-01-2021, 12:39 PM   #7
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This is a ball flange connection with 2 bolts, there’s no gaskets.
Old 10-01-2021, 12:39 PM   #8
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
3/8 x 2 1/2” Grade 8 Flange Bolts
Old 10-01-2021, 02:13 PM   #9
FoundNemo
Drives: 2019 ZL1
Thats what I am using, Grade 8 not stainless and they keep coming loose. Antiseize to hold them tight? I can try with flat washers too if that will help.
Old 10-01-2021, 02:14 PM   #10
FoundNemo
Drives: 2019 ZL1
So flat washer first against the flange, then lock washer against the flat and the bolt through them? Will give that a shot now.
Old 10-01-2021, 03:18 PM   #11
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Stage 8 Locking Fasteners
For any header or other ultra high temp exhaust application like this (like a turbo hotside) I recommend Stage 8 locking fasteners.
https://www.stage8.com/
Once installed correctly they cannot loosen, they're mechanically locked and easy to remove.
Another option are Nord-lock washers, they work well too but not as 100% certain.
https://www.nord-lock.com/nord-lock/products/washers/
SFV1LE is offline   Reply With Quote
Old 10-01-2021, 03:26 PM   #12
Evansa22
Evansa22's Avatar
Thanks
Old 10-01-2021, 05:23 PM   #13
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
They should not be coming loose. Make sure the rest of the exhaust is tight and there’s no slop that could vibrate either your cat pipe or off-road pipe. Should be no Movement. If there’s movement the ball socket can move which would have an effect on the tightness of the bolts.
Flat washer on the flange side, lock washer nut side. Crank them down until they are tight, but don’t bend the flanges.
Old 10-01-2021, 06:03 PM   #14
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Safety wire? Commonly used in motorcycle road race applications.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
