Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Anyone know how much poke ZLE front actually is?
Kind of an odd question, but anyone know how much poke ZLEs actually have outside fender with street alignment? Are wheels themselves flush and it's actually tire poke? Or does wheel poke as well?
I'm installing longer front studs on my ZL1 to fit a spacer on stock wheels, but since it's not a ZLE I'm only after making them flush. I would/should have measured this myself, but lowered the car last weekend and alignment won't be till next week to measure and would like to order spacers now since they'll need to be made. 5mm isn't enough, thinking 7mm may be good unless it's actually tire poke only on a ZLE. Thanks for any info!
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
Sarcasm loading --------
they stick out about 1/2 inch front and back.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
Thanks for the reply! Would that be around 1/2" including tires or just edge of wheel?
with tires.
Thanks for this info, it appears the tire and wheel sidewall of the ZLE is flush with the wheels. Plugging in the info and knowing the 1LE has ~12.7mm of poke, looks like if I wanted the front wheels to be flush to fender, 9mm spacer should do it. May go with 8mm for any variances to the inside or outside, but in reality no one would notice either way.
![]() Drives: 2020 ZL1 1LE A10 Join Date: Feb 2021
To make your stock ZL1 wheels fit like ZLE wheels in regards to the fenders, you'll need 24-25mm spacer up front and 14-15mm spacer in the rear.
Mark |
#7 | |
Since I have a non-1LE, I'm just aiming to get my stock wheels to sit more flush with the fenders. I think/hope it'll look just a bit more aggressive with the wider "stance" (as the kids say). Very well could be a waste of time and money, albeit not alot, but time will tell.
#8 |
Nah, definitely not a waste. Flush is the way to go all day. I put 20mm spacers front and rear on my ZR1 and it was perfect. Always got comments on the stock wheels because of it. I'd probably start with 20 and 10 mm spacers and then on ebay you can get some 2mm or 3mm spacers to "fine tune" the "flushness". Have fun!!
Mark |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
always depends on how much camber you have
ill be putting on 19x11 19x11 wheels next year but i have -3.5 camber in the front so it shouldnt be too bad of poke on my ss
#10 | |
Since I have 3/5mm already, I'm happy with the 3mm on it now but always been curious to see how 5 would look. Ideally would be great to have just a single spacer on each wheel, one less thing for me to some how misplace in my shop, lol. But I like your idea, stay with a typical and cheap non hubcentric spacer size and get some smaller ones to tinker to get what looks best. Or now that I think about it, just use washers temporarily and then order a custom size hub centric set afterwards. Great suggestion, thanks! So true! I didn't mention it and should have, but I daily the car so will have the OEM alignment for tire wear, but definitely good point I can adjust it a tad if I want to.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Yeah I agree 20mm front and 10mm in the back should be plenty to make it flush and not poke.
#12 | |
After an alignment next week, I'll double up the 5mm I currently have on one side to see how it looks. I'm hoping it'll have enough thread engagement that I can put the car on the ground and move a little bit for suspension to settle and find out how it looks. I'll definitely snap some pictures and post to share my findings.
#13 |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
^This^
FWIW, 0 poke on ZLE with minimum -2.0 camber front, 1.5 camber rear at +-0 toe. I run -2.2F, -1.6, +-0T on the street. My outsides wear way too fast on standard alignment. There is no poke at all with a more aggressive track alignment (3.0+F, 2.0R, +-0T is my happy place).
2018 ZL1 1LE sw/PDR
#14 | |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
I leave mine at 3.0 front, 2.0 rear always, switching is too costly and time consuming. I usually get a new alignment before each event. I always have several sets of tires and after a track event I usually run the last track tires on street. I never drive in cold or rain, but if its a daily I know this doesn’t work. |
