2017 HyperBlue 2SS
Battery!
I was just quoted a price of $385 installed for a new battery! It’s a 48 month glass mat battery. Does that seem insane or what?
http://www.camaro5.com/forums/showthread.php?t=30755 2010 IBM 2LT RS......Traded for..... 2012 IBM 2SS RS......Traded for..... 2017 HBM 2SS |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Yeah, I'd just get an Optima and an AGM charger and use the charger regularly.
![]() Drives: 2018 SS 1LE Join Date: Sep 2018
My local walmart has the H6 battery with the side ventilation holes for about $120. Its the Everstart Maxx. I haven't have the needs to change mine but that's the route i'd go with.
![]() Drives: 2019 Camaro 2SS Satin Steel Gray Join Date: Sep 2019
I work at a battery shop here in Eastern Washington State. a Group 48 AGM would run $219.95. 48 Month and made by Deka(USA Made). Personally I would stay away from Optima. They once were the best you can find but quality and longevity have been greatly reduced in the last 2-4 years. Once Johnson Controls bought them they moved production and the quality has dropped. Stick with Deka or Odyssey if you want one that lasts.
2019 Chevy Camaro - 2SS - Satin Steel Gray Metallic - RotoFab w/Dry Filter and Sound Tube Delete, Borla S-Type Carbon, Mishimoto Catch Can, (2) Banks iDash Gauges in ZZP Pillar Mount, DD Side Marker Lights, EOS Gloss Black ZL1 Splitter, Ikon Gloss Black Rear Diffuser
2004 Chevy Trailblazer - LS 4.2l - Black - 3.5" Lift, Custom Interior, Custom Roof Rack and Grille w/Built-in Light Bars, 285/55R20 on Trailblazer SS Wheels |
2017 HyperBlue 2SS
How about this one?
This will be the same battery that came with your car from the factory. AC Delco is also owned by Johnson Controls. I try to stay away from any battery they make but some people swear by them. To be fair the Silver Calcium composition is actually very good. Helps fight that internal sulfation even more on top of it being AGM.
I would call around to local battery shops and se what brands they carry. If you need to warranty it buying off the internet might make things harder and more expensive, where buying local makes warranties easy and helps support the little guys.
#7 |
2017 HyperBlue 2SS
Bought the battery from Amazon. OEM battery for $175. Dealership installed for $40. $215 total. Better than the original price they quoted me of $385 installed buying the battery through them.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
sounds about right i had to get my stock one replaced around 3 years in...
#9 | |
Luckily I got my battery replaced at the very end of the 3 yr btb warranty. I am hoping using my CTek charger regularly will help it last longer.
#10 |
antigravity > optima lighter stronger and better haha
#11 |
I get Deka AGM batteries for my jet ski's through Lowe's web site. Ship to store for free. Agree they do last and typically they are stickered with a build date a month or two prior to my order. I have used Odyssey and I think deka is superior.
#12 |
![]() Drives: 2018 ZL1 Join Date: Jul 2017
I have had great luck with Odysseys since Optimas took a dive.
I have not had to replace one yet. The one in my Vista Cruiser has been in there around 15 years. Still works great. The 2 in my Bronco still start it every time no problem but are getting tired. They are around the same age.
Mark E.
2018 ZL1 NGM A10 87 Grand National. Modified Hot Rod for sale *SOLD* 87 Grand National. Stock 65 Olds Vista Cruiser wagon Grand National motor/tran 66 Bronco Rockbuggy 2006 Dodge 2500 4x4 Cummins 6 speed |
#13 | |
I needed to change my old factory battery out. Went with the Walmart's Everstart Maxx H6. No issues here |
#14 |
![]() Drives: 2016 camaro Join Date: Mar 2018
I'm happy with my Odyssey battery. Bought it 7 years ago.
