![]() Drives: 2021 chevy camaro LT1 Join Date: Aug 2021
How much will coast roughly to fully build lt1 engine ?
Hey guys so I got the 2021 camaro lt1 and I want to get fully build engine and one of my local shops told me around 10k is it good price do you guys have any ideas?
Thank you |
Moderator
What do you mean by “fully build”? It’s easy to spend more than 10K if you’re going all out, that’s for sure. What are your goals?
17’ Hyper Blue 2SS
Enough to ask the question “why didn’t I just get a zl1”.
Candidly, your post doesn't make it seem that you know this topic. First, the short block is already custom (forged/billet) from GM, which narrows the topic down to your getting P/P heads and a custom valve train (cam, lifters, push rods, rocker arms, valve springs, and intake/exhaust valves). Mine made 725 with this, a tune, 10% lower pulley, Kooks LT and HiFlow cats. The cost would vary significantly from shop to shop.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#5 | |
![]() Drives: 2019 Camaro SS Join Date: Nov 2020
The LT1 is pretty strong in stock form, it simply has tight ring gaps by design. That combined with high compression narrows the window of error. So extra measures to be taken when boosting them. If the rings were gapped for boost these engines would be living @ 850-900whp pretty easily.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
I agree with Joshinator99 that you will want to define your goals before you start the build. Once you have a list of modifications then the forums can help you decide if you're getting a decent price for the work. Since you list your location as California you will want to understand CA's new inspection laws and how they impact you before you start your build.
#8 |
Sorry, I was as always referring to the LT4
2020 ZL1LE A10.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
ill build you a motor for 10k lol
#10 | |
So we are going to add the blower kooks catless long tube headers full gt haus exhaust system going to upgrade the fuel system and the tune for engine and trans and my shop said that we can do cams pistons pushrods and some internal upgrades that we can push around 800whp to be safe not blowing anything. It's just going to be a weekend car. Thank you |
#11 | |
Awesome to know thank you |
#12 | |
But you think if I do cams pistons and other internal upgrades will be better for the car? It's just going to be a weekend car so people say you don't need that if you are not going to take it to the track. But I think that will make my car engine more safer? Thank you |
#13 |
![]() Drives: Chevy Camaro Join Date: Apr 2020
A complete “built” turn key engine from most of the big name engine shops is in the 25,000 dollar range depending on what options you get.
#14 |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
Why? He has and asked specifically about an LT1, so LT4 info. is irrelevant.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
| Tags |
| lt1 6.2l engine, performance chevy |
