Go Back   CAMARO6 > Marketplace > Members Classifieds > Suspension / Chassis / Brakes
Old 09-28-2021, 10:29 AM   #1
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
WTB Hotchkis 22118F adjustable sway bar
You can text 817-919-6866 if you have one to sell
Thanks!! Greg
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 10-22-2021, 03:16 PM   #2
sr71bb
sr71bb's Avatar
Material Shortage
NEVER MIND. Apparently due to a material shortage, this wont be available until at least 90 days.
Retired Cars BELOW:
Old 10-28-2021, 02:22 AM   #3
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
I got a rear if you want it
RobertAvitia is offline   Reply With Quote
Old 10-28-2021, 06:24 AM   #4
sr71bb
sr71bb's Avatar
Thanks Robert but I got all the new sway bars installed now front and rear BMR with end links and all. I bought that high dollar $300.00 front sway bar billet bearing cradle holder and upgraded delrin bearing (SBB010)so that I could eliminate the POS stock bearing set up that the front BMR sway bar comes with.
So far everything works great with front bar set to full siffness and rear bar on middle setting.
Retired Cars BELOW:
Old 10-30-2021, 06:31 AM   #5
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I didn't know about SBB010. interesting it doesn't show up on BMR website but does on others. Have any pics of it?
Old 10-30-2021, 10:29 AM   #6
sr71bb
sr71bb's Avatar
SBB010
No It wont show up on their website because it is a NEW part for them. You can order it DIRECT by calling them or SUMMITT or WILDHAMMERMOTORSPORTS has it on their websites
This part was developed specifically because the bearing provided with the BMR kit was splitting under extreme pressure because the bearing cradle apparently wasnt strong enough to support it under extreme conditions such as in road racing or autcrossing. The STOCK bearing would split in these situations. They developed this part which consists of a BILLETT steel bearing cradle and heavier duty DELRIN bearing. This part by itself is a little over 300 dollars but it appears to haver solve this issue.
Although the REAR BMR sway bar uses the same bearing holders and bearing as the front, it is NOT necessary to get the SBB010 bearing kit for the REAR as the stock set up appears to work fine.
Now had the HOTCHKIS bar been available at the time, I would have gotten that sway bar for the front instead of the BMR.
I DONT Have pics of the part because we put it on as soon as we got it so that we could go racing the next day.
Retired Cars BELOW:
