![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
CATCH CAN FOR TRACK USE
i got my elite v2 catch can installed a few months and havent been to the track since how often do you guys check it when you track the car? ive only put about 300 miles on the car since its installed and first track day is sunday
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I have the Elite X2 ultra and I drain it everytime when I do an oil change. And it fills up only about 1" of a water bottle.
thanks for reply
![]() Drives: 2024 2SS 1LE Join Date: Sep 2021
Does the LT1 *really* need a catch can? I know a lot of people install them, but are they really needed?
My LS1 required a can for racing, but it seems GM tried to engineer this issue away. |
![]() Drives: 20 SS 1LE Join Date: Jun 2020
I drain mine prior to any event, and there's usually just a thin layer at the bottom. I wouldn't recommend letting it get too full, as it could slosh up and get sucked into the intake anyway in that case.
It's a DI engine, so it's best to keep all oil out of the intake tract so it doesn't coke up your intake valves.
John Hale
multi time solo nats runner up :( |
I used to think the same way, but I had an extra few dollars and decided to pick up a Mishimoto Catch Can. Drained it after my next oil change and after I dumped out what would have went right back into my intake, I am a firm believer in them now. Especially since these are DI engines.
#7 |
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
I've had one day 1 from my car. This is from my journal page -
https://www.camaro6.com/forums/showt...=594295&page=3 |
#8 |
I check it before any event and if I have done any hard driving. Ussually have something in there but nothing crazy.
I don't DD/cruise it that often. Really only to local C&C and to the track. |
#9 | |
yup same here lol i gotta log how many miles i actually do but its probably 2-3000 miles a year at most probably have more on track miles than street miles
#10 |
thanks guys i did my first track day on sunday ill check it next weekend
#11 |
Ideally you would have one that would show how full it is without opening it. Also have an easy drain method. Do they even make one with these features?
#12 |
![]() Drives: Camaro 1ss Join Date: Nov 2019
Mighty mouse catch cans have a sight glass window on the side of them. They also have a petcock drain on the bottom. I just cut a water bottle in half place under petcock and open it up let it drain.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
#13 |
no sight glass on mine but does have a petcock drain on bottom just have to loosen up mount and empty it ill check mine out sunday when i give my car a after track bath/clean up
#14 |
finally had time to empty it with probably 500 miles on it 1 auto x day and 1 track day and there was nothing in there i mean maybe 10 drops of oil or so...guess thats a good thing so probably will only check/empty it every 3 months or so
