![]() Drives: 2017 ZL1, 1995 Trans Am Join Date: Jan 2017
Track Mode & PTM mode - getting them to work
Can someone confirm when you select 'Track' as the drive mode and then in my case I am selecting 'PTM - Sport 1' you must select ok (center button) for it to save the setting.
My only issue is traction & stability (orange light stays on for both). This isn't right? Am I doing something wrong to turn on? I have selected PTM - Sport 1. I checked the manual and it evens says the two orange lights will stay on when you select a PTM mode? Kinda of scary if you ask me because it is suggested both traction and stability are off???
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof Last edited by Canadian ZL1; 09-26-2021 at 03:41 PM. |
#2 | |
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#3 | |
I checked the recording from my PDR and in fact it shows Sport 1 under PTM and Track mode BUT the picture I posted shows the solid orange for Traction and stability???
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
You don’t have to press okay. Just up or down to the desired setting. Then it’ll stay in that setting until changed. You can also simply press up or down again and change the PTM on the fly from say sport to race.
I can’t confirm on the dash lights simply because I’m not driving and away from the car. |
#5 | |
I am still curious why the TC and Stability lights stay on dash? The manual says they are supposed to be on but only when PTM mode is selected. Just doesn't make sense to me??
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Yes the warning light(s) WILL stay on. It's there to let you know you better not floor the throttle and expect traction control/stability to help.
I can't remember if sport comp mode does the same thing. What GM should have done is put a symbol up for sport comp and PTM. The link JSH posted does explain this. The PDR will not show that the nannies are on or off. It will show when the car loses traction, the car fishtailing symbol,, but nothing else. That's in any mode. |
#7 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Traction Control and Stability Control lights will be on while in PTM, you have turned off the standard Traction/Stability Control and now are using PTM Traction Control and Stability control, all is normal! Agree, wish there was a light for PTM.
I only ride around in PTM, the standard Traction Control and Stability Control have no idea how to handle the extra 250 whp my car has, PTM Traction Control and Stability Control can/do. My usual turn on is: Track, tap TC twice, down down (Sport 1), select, rev match enabled.
#8 | |
#9 | |
If you are pushing an additional 250 rwhp I'd say keep all the nannies on and I am assuming you are suggesting PTM Sport 1, Sport 2 or Race does not help you! So you probably just keep it in standard Track mode with PTM not enabled.
#10 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
The orange light stays on in Sport 1 and 2. You still have some of those functions working in Sport 1 and 2. I believe in Race all of the traction control and ECM are turned off.
#11 |
You will need a team of people logging and studying data to figure out which of the gazillion modes is best for a particular track/day.
2020 ZL1LE A10.
#12 | |||||
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Interesting I've never seen anyone mention that you can change PTM modes on the fly with the buttons above and below the ok button on the right side of the steering wheel. I'll have to try it and verify with PDR. Seems kind of dangerous if it doesn't show any visual confirmation of the mode change since you could accidentally press it while cornering and not know. I have done it by tapping the traction control button once, then double tapping it twice, then selecting the new PTM mode but it is hard to get all of that done correctly on a straightaway on track at speed before the next braking zone. Quote:
#13 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
I can confirm that you can change PTM modes on the fly, as I have done it quite a few times. There is no need to tap the traction control button once, then double tap it twice and then select the new PTM mode.
Mosaic black 2018 Camaro 2SS A8 (sold) |
#14 | |
Makis
