Old 09-21-2021, 02:11 PM   #1
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
Will 30/68-18 Fit the from of a ZL1 1LE?
I bought the 18" Apex wheels in ZL1 1LE size. Usedracingtires.com says the Michelin 30/68-18 will fit. Has anyone tried them?
Pollock is offline   Reply With Quote
Old 09-21-2021, 02:54 PM   #2
PROMETHEUS
PROMETHEUS's Avatar
They will fit. However, with the 18 inch wheels you have to use a 3-5mm spacer, along with grinding down the knuckle on the strut.
Old 09-21-2021, 03:50 PM   #3
Pollock
LT4 M6
Pollock's Avatar
The wheels are already ET7 vs ET11 stock. Your saying I will still need more offset?
Old 09-21-2021, 04:11 PM   #4
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
No, you'll be fine.
seanblurr is offline   Reply With Quote
Old 09-21-2021, 04:19 PM   #5
el_d3sconocido
Drives: 2018 ZLE
What size do they recommend for the rears?
el_d3sconocido is offline   Reply With Quote
Old 09-21-2021, 04:38 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
little bit tall but worked fine on my car...they rubbed a hole in the wheel liner. 660 is more appropriate
Old 09-21-2021, 04:48 PM   #7
Pollock
LT4 M6
Pollock's Avatar
Okay. I ordered 30/65-18 for the front.
Old 09-21-2021, 05:04 PM   #8
Pollock
LT4 M6
Pollock's Avatar
33/68-18 which are hard to get now so I am trying the 30/68-18
Or 325/680-18 pirrelli tires.
Old 09-21-2021, 08:44 PM   #9
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
On MY SS I am running Michelin Slicks 30 68 18 on APEX EC7 18 x 11 wheels with ET27 offset. I run these on all four corners and I use a 5MM spacer on FRONT and also did some grinding on the strut bracket for clearance.
They Work GREAT with no POKE at the top of the wheel wells. An ZL1 will have a little more clearance than an SS up front. Running -3.1 camber on front and -2.4 camber on the rear. I also have used Pirelli 305 660 18 on same wheels. I like the larger diameter of the 30 68 18 Michelin Tire
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
