![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
EMPTY GAS TANK W/ HP TUNERS HELP
Hey Guys,
I disconnected the fuel line at the flex fuel sensor and ran a hose to the gas can. When I select enable fuel pump (under Vehicles/Special Controls and Functions/Fuel Systems/Enable Fuel Pump), it will only run for three seconds and them stops by itself like it has a predetermined timeout point. It pumps gas from the tank, but then stops. Any thoughts would be greatly appreciated. Thank you, Martin
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
Perpetual Order
Drives: indeed Join Date: Jun 2012
yeah hpt is only turning on the priming function.
jump the fuse instead. |
![]() Drives: 2019 ZL1 Join Date: Oct 2019
Caps lock.... yikes
I assume you are talking about the fuse in the trunk. Can you tell me what fuse to look for exactly (I'm a little hesitant about putting voltage to things I'm not familiar with)? And I just jump 12 Volts to the proper fuse? Thanks.
