Old 09-17-2021, 11:17 AM   #1
teddyca
teddyca's Avatar
Drives: Blown C7 and 6th gen
Just got kicked in the nuts - Installed flex kit and cant use LOL
Welp good thing it only took me about 45 minutes and $250. So as some of you know I am in the middle of a crazy C7 build where skies the limit. The Camaro on the other hand is my daily. I take that girl golfing, road trips, the bars, you get the idea. LOL It has a maggie, intake, x pipe, and Corsa. Runs and sounds perfect. NO plans to touch the fueling on this car. Well just spent almost $100 filling her up at $5.09 a gallon in Norcal and said I am over this chit and installed Lethal Garages flex system last night. I talked to a very reputable tuner and was told my LT1 fuel can not handle E85. I was told I would need to do fuell LT4 fueling and a boost a pump. Well I am doing all that as we speak on the C7 but have 0 plans to do anything like that to Camaro. So now it looks like I installed the kit and Aeroforce gauge for no damn reason. Lesson learned here boys research.
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL
17 Camaro 2SS 50th edition. TOTALED 6/2019
K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system
17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system.
teddyca is offline   Reply With Quote
Old 09-17-2021, 12:38 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I don’t believe that an otherwise stock LT1 requires LT4 fueling to run E85. There are numerous threads on the topic. There are several reputable tuners selling E85 kits for the LT1 that only included the sensor, wideband, and tuning to enable E85 in the ECU.
Old 09-17-2021, 12:43 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Believe the car has a Maggie...
Old 09-17-2021, 01:05 PM   #4
Mark114
Mark114's Avatar
Oops. My mistake. I misread and was thinking the Maggie was on the C7.
Old 09-17-2021, 02:45 PM   #5
teddyca
teddyca's Avatar
LOL Josh is correct. The ole Camaro has a 2300 on her. HAHA My actual tuner said I can run a blend if interested on LT1 fueling. So we shall see. The C7 on the other hand has an A&A kit with a host of goodies. I am chasing 1000hp on that build and should be close. My fricking C8 needs to get here already so I stop dumping money in these other cars. I got issues. LOL
Old 09-17-2021, 06:07 PM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I believe I mentioned a while back you wouldn't be able to run e85 on the Camaro with stock fuel system. I believe I also said you would need the full LT4 fuel system to run any E. I also doubt you will get to full E85 with the LT4 stuff unless you turn the boost down to 6psi.
Old 09-20-2021, 12:50 PM   #7
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Just grab 3 more mods. it never ends....... lol You will get more.
1.) Fuel pump
https://www.cspracing.com/factory-gm...pump/12688607/
2.) Low side fuel kit stage 2 for E85.
https://weaponxmotorsports.com/produ...13625961447473
3.) Lt4 Injectors if u don't have them already.
https://www.cspracing.com/gm-oem-lt4...2374/12682374/
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 09-20-2021, 02:39 PM   #8
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
scoggin dicky has the injectors for 450 clams.. whoops now 492 they were 450 about 2 weeks ago.
Old 09-21-2021, 01:36 AM   #9
toohighpsi
Drives: 2015 C7 Z06 M7
King is spot on, with our LT1 we weren't able to run much of any boost with full E85. If i remember correctly it was like a bit over 450 RWHP when we hit the limit. So while we still use the stock LT1 high side, all fueling over the 450 (to the current 728 RWHP) is handled by the port injection system.
Mike
www.toohighpsi.com
2015 Corvette Z06 M7
2021 Porsche GT4 M6
2023 Corvette Z51
