Old 09-17-2021, 10:44 AM   #1
hallass66
Drives: 1968 LT4 Camaro
swapping pulley
I purchased a camaro with the magnuson 2650 full exhaust and CAI.Also has alky meth with a dual nozzle.Car was tuned by a good tuner.The problem is it has a stock LT1 engine.Top pulley is 100mm and bottom crank pulley 10% over.I was told by magnuson that would be roughly 11lbs of boost.Im going to be putting a 110mm pulley on top to lower the boost a couple of pounds.Do you think by dropping the boost the car will need to be retuned?
hallass66 is offline   Reply With Quote
Old 09-17-2021, 11:01 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It might depending on how it was tuned. Only way to know is datalog after swap.
Old 09-18-2021, 06:45 AM   #3
hallass66
All i have right now is a AFR gauge.I havent had time to get the HP tuners.Im just trying to make the car safe til i get rods and pistons.
Old 09-18-2021, 06:51 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
King is right, of course. You should definitely drop the boost to 7-8 until you have a firm handle on your tune & fueling. Pick up the HP Tuners MPVI2 now and learn to use the scanner ASAP. Keep your foot out of heavy throttle until you know what’s going on.
