Old 09-12-2021, 02:59 PM   #1
FoundNemo
Drives: 2019 ZL1
P042B Code resolved - Service Restraint System
Had a random and sudden P042B code and a service restraint system pop up today after a hard 2nd gear pull through 4th. No other codes, no MIL but airbag light on. Scan showed that there was a lost communication with Body Control Module "A" which apparently could be one of like 100 modules on the car.
A bit of google searching, main harness checks and figured it out promptly. Turns out one of the connectors under the passenger seat (by the front of the left lower rail) had unclipped completely. Easiest fix ever. It was very obviously unplugged.
Cheers to anyone else who experiences this, apparently happens on the c7 vettes too.
FoundNemo is offline   Reply With Quote
Old 09-12-2021, 03:03 PM   #2
Flowtie1
Drives: 2017 ZL1
Thanks for the heads up !
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 09-12-2021, 03:58 PM   #3
FoundNemo
Drives: 2019 ZL1
Anytime! Always happy to share easy fixes. First place I went was the engine bay to check the harness by the headers but that harness is fully wrapped in DEI shielding and far away from the CSP headers, so had serious doubts it was that. Easy fixes are the best.
Old 09-12-2021, 05:00 PM   #4
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Glad it was that easy.
Old 09-13-2021, 05:12 AM   #5
FoundNemo
Drives: 2019 ZL1
Thx sir!
Old 09-13-2021, 02:11 PM   #6
serper3
serper3's Avatar
Drives: 2018 Camaro ZL1 1LE
Oh man! This would happen to my 2008 c6 corvette.. I would get an airbag light on the dash. the connector under the seat would wiggle loose. I finally had to zip tie it tight.
glad it was an easy fix though.
serper3 is offline   Reply With Quote
Old 09-13-2021, 02:34 PM   #7
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Nothing like an easy fix!
pauly1119 is offline   Reply With Quote
