Old 09-12-2021, 06:57 AM   #1
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
LTG ENGINE COOLANT CAPACITY AND TYPE
Hi there!!,
does anybody know what is the exact COOLANT CAPACITY and COOLANT TYPE in order to make a full change on an LTG 2,0 turbo engine?
I can't find this info on the documents I have here and my car is almost five years old now.. so I guess a good "refresh" of the coolant system could be a proper idea.
Thanks!,
Eos
Eos is offline   Reply With Quote
Old 09-13-2021, 10:43 AM   #2
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
I'm not sure if you need to know the exact amount... just release the petcock valve on the bottom passenger side of the radiator. Let it completely drain out than fill it back up along with the overflow tank. Start the car, let it idol for a while and re-check.. That's what I do... am I missing something here???
Also, I use Mishimoto...
https://www.mishimoto.com/liquid-chill.html
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 09-16-2021, 02:09 PM   #3
Eos
Eos's Avatar
Hi!,
thanks for answering to my question!
Yes.. that would be the ideal situation, as I live in Italy and knowing the exact quantity before draining the system would be perfect, as I'll have to source/order DexCool before I do the job on the cooling system. Unluckily, here it's not so easy to find GM parts and have them quickly, right when you need them.
No... you're not! You are essentially following GM's instructions (workshop manual) on how to flush it.
See you!!,
Eos
Old 09-16-2021, 03:59 PM   #4
95TA - The Beast
Drives: 2014 Cadillac CTS4 2.0T Performance
I did a complete coolant system redo on my 2014 CTS and did it the same way.
Be sure to have a cooling system vacuum fill device before you do it. It will make sure there is no need to purge the system of air. Fill and done with one of those. Great tool.
95TA - The Beast is offline   Reply With Quote
capacity, coolant, ltg
