Old 09-02-2021, 09:09 PM   #1
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
Changing oil and filter
well autumn is almost here so will be changing my oil and filter before i close it down for the winter.
just wondering if the filter change is as easy as it is on the gen5 camaro's?
plus what size the drain plug bolt is?
i know our cars have a under tray.does that need removing to change the oil and filter?
cheers
Camaro fanboy is offline   Reply With Quote
Old 09-02-2021, 09:43 PM   #2
ifound1dollar
Drives: 2017 Camaro 2LT RS Hyper Blue A8
Same, actually, I like to change my oil once the monitor gets to ~20% and/or before winter.
It’s honestly easier than the gen 5s IMO, the 6s have a canister filter which I feel is much easier to work with. I should note that I have a V6, but I don’t think there’s much difference between the 6 and 8 except for the filter part # and oil volume (someone correct me if I’m wrong). The drain plug is 13mm if I remember correctly, and you shouldn’t have to remove anything on the underside of the car. The plug and filter are easily accessible.
ifound1dollar is offline   Reply With Quote
Old 09-02-2021, 10:21 PM   #3
No need to remove the tray, the filter is an easy to handle screw-on type, you can remove it by hand or using a 74mm 15-flute oil filter wrench.
Drain plug size is M12x1.75 mm, and you might want to consider this valve plug to make oil changes easier and less messy: https://www.amazon.com/gp/product/B01AMXATSC
Old 09-03-2021, 07:04 AM   #4
Camaro fanboy
cheers fellas.
i got this oil filter. i think it's correct.
MOBIL 1 ok?
Old 09-03-2021, 01:04 PM   #5
Filter's good. Mobil1 dexos 2 full synthetic 5W-30 or 0W-40 will be fine, though it isn't the only option.
Old 09-03-2021, 09:14 PM   #6
Camaro fanboy
cheers dude.
i always have used mobil 1 and never had a problem.
takes a lot more oil than the gen5 doesn't it?. 10 liters?
Old 09-03-2021, 09:53 PM   #7
Nitefall17
Drives: Camaro 1SS A8 Vert
10 quarts
Nitefall17 is offline   Reply With Quote
Old 09-03-2021, 10:11 PM   #8
Yup, 10 quarts (9.45 liters).
Old 09-03-2021, 10:53 PM   #9
Camaro fanboy
thanks lads
Old 09-04-2021, 09:09 PM   #10
SSUNDVL
Drives: 2016 Camaro SS
How much does 10 qts oil run in Sweden?
SSUNDVL is offline   Reply With Quote
Old 09-05-2021, 07:36 AM   #11
Camaro fanboy
about 130 USD. everything is expensive here.
loaf or normal bread almost 4 USD.
Old 09-05-2021, 10:20 AM   #12
SSUNDVL
Ouch that is expensive but I was thinking it could be more. At least you have some killer roads to enjoy the Camaro on.
Old 10-05-2021, 11:15 AM   #13
Camaro fanboy
all went well. old filter was a bitch to get off though
did the new ac delco filter up 3 quarters turn from when it first bit.
mobil 1 esp oil 5w30 and now i feel good. always like to know what oil my cars have in them
Old 10-12-2021, 11:14 PM   #14
PhotoGuy
PhotoGuy's Avatar
Drives: 2020 Camaro 2SS .. chevy silverado
LOL Got you beat in Canada engine oil from the GM Dealer is $24.93 a litre and rear diff oil is $35.00 a litre CDN
PhotoGuy is offline   Reply With Quote
