Old 09-01-2021, 02:00 PM   #1
Blueclyde
Drives: 2023 ZLE
Track Specific Wheel and Tire Set-Up
Looking for input on a track specific set-up for a ZL1 (non-1LE). I have a lot of track experience and am going to be purchasing a track specific set-up over the winter.
I am leaning toward a square set-up with 305s. I haven't picked the tire yet but something like a Nankang AR1 or similar. The tire I chose will likely didcate wheel size, but I beleive both 18" and 19" can be made to work on the ZL1.
Very interested to hear from those of you with track specific set-ups. This car feels like it would be better with a 305s all the way around.
Blueclyde is offline   Reply With Quote
Old 09-01-2021, 03:33 PM   #2
20Bluezl1
I love the ZLE tire setup, I bought Apex wheels and run 325 R and 305F. I also just installed camber plates to make it easier to get more camber.
Old 09-01-2021, 07:28 PM   #3
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
+1
1le footprint with Arc 8s
Home Track: NCM Motorsports Park
Heartbreaker is offline   Reply With Quote
Old 09-01-2021, 07:50 PM   #4
Blueclyde
Drives: 2023 ZLE
What tires do you run? I presume 19” wheels? What camber plates do you use?
Old 09-01-2021, 07:59 PM   #5
20Bluezl1
I run 3R on 19" and Vorshlag camber plates. Also this is a good fitment article from Apex.
https://support.apexraceparts.com/hc...-Fitment-Guide
Old 09-01-2021, 08:21 PM   #6
Blueclyde
Drives: 2023 ZLE
Thanks for the info!
Old 09-01-2021, 08:52 PM   #7
BanOne
Drives: 1977 Pontiac Trans Am
I run 305 all around on APEX EC7 10.5 " rims, that way they are rotatable and I can get a bit more out of the tires.
BanOne is offline   Reply With Quote
Old 09-02-2021, 05:56 PM   #8
SebV19
SebV19's Avatar
Drives: 2019 ZL1 1LE
I run 18' BC Forged RZ05's. They are great, really no complaints but I have a 1LE so they are in BC Forged's 1LE specs
2019 ZL1 1LE A10
AP Racing Brakes - MCS/Vorshlag 2WR - MFR Engineering Diffusor + Flat Floor - C&R Oil Cooler + Heat Exchanger - Piper Motorsport Cage - Anderson Carbon Doors + Trunk
SebV19 is offline   Reply With Quote
Old 09-03-2021, 07:45 PM   #9
Blueclyde
Drives: 2023 ZLE
I was checking out those camber plates and have a few questions.
Is it pretty easy to adjust the camber?
If I had a street and track set-up, is it as simple as changing camber from street to track once you have a base alignment?
I understand front suspensions and alignments very well. Is the main advantage here, for my purpose (larger wheels and tires up front), moving the pivot point to prevent wheel to strut contact? It seems likely that the ZLE uses these for the same reason (more negative camber without wheel to strut contact).
How is the durability of these aftermarket plates? They look beefy but I get weary of aftermarket parts like this, especially for track use. These companies just do not have the ability to validate durability like the OEs.
