Old 08-27-2021, 05:00 PM   #1
Silent_H_
Silent_H_'s Avatar
Drives: '21 V6 1LE
Brake fluid factory fill DOT4?
I've been looking into doing all the things I need to do to prep my car for a track day. One of those things was to swap to DOT4 brake fluid. Looking at the fill cap, though, I see that it says only fill with DOT4. That leads me to believe that maybe the factory is already using DOT4.
Anyone know the answer?
Silent_H_ is offline   Reply With Quote
Old 08-27-2021, 05:09 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
you want to use dot4 high temp fluid motul 660 or castrol srf is the best ones
Old 08-27-2021, 05:24 PM   #3
Silent_H_
Silent_H_'s Avatar
Drives: '21 V6 1LE
Ah ok, so while it may be DOT4, it's still not quite going to cut it on track vs a DOT4 made specifically for racing with a higher boiling point?
Thanks!
Old 08-27-2021, 05:46 PM   #4
kropscamaro16
correct !
Old 08-28-2021, 09:33 AM   #5
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Thanks!
DOT4 only specifies minimum boiling points (446°F dry, 311°F wet). Fluids can test higher and still be DOT4, but not lower.
I couldn't find specific boiling point numbers for GM's DOT4, so in the absence of actual data you should only assume the minimums.
Norm
Old 08-28-2021, 10:16 AM   #6
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
For track, the recommended fluid is Castrol SRF or Motul RBF 660. I've also heard good things about the Brembo fluid, but I haven't used it. SRF is preferred over Motul 660 but it is also the priciest.
Edit: I skimmed the thread too quickly. Didn't realize krops already covered this
YouTube
Old 08-28-2021, 11:59 AM   #7
aronSlusa
aronSlusa's Avatar
Drives: '16 2SS
Used Brembo LCF 600+ during my last couple track days and was not impressed compared to Motul660 despite the wet and dry boiling points supposed to have been a little better in the Brembo vs Motul. Pedal did not feel as firm with the Brembo.
Absolutely hated the Stoptech 660F the one time I ran it; could not wait to drain it out of the system.
aronSlusa is offline   Reply With Quote
Old 08-28-2021, 01:47 PM   #8
Silent_H_
Silent_H_'s Avatar
Drives: '21 V6 1LE
Thanks everyone! I'll likely go with Motul RBF 600 or 660 unless there's a good deal on the Castrol SRF.
Old 08-28-2021, 08:34 PM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Endless works great...consider that as it has good longevity and costs a little more than Motul 600 but far less than SRF.
Old 08-28-2021, 09:43 PM   #10
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
I'm almost positive the stock fill is DOT 3. Big difference going to DOT4.
Ken
khcoaching is offline   Reply With Quote
Old 08-29-2021, 01:51 AM   #11
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
The stock fluid is DOT3 and a very average one at that. I changed to Motul DOT 5.1 and even that made some big differences compared to the stock stuff. Definitely change it out if you are heading to a track.
I am currently using Motul RBF 600, but if you track enough, Castrol SRF might make more sense to you. It will cost you a shiny penny, but the highest known wet boiling point for any brake fluid on the market right now means you can run the same stuff probably for the entire season without worrying about fade. Can save you time and money when you have to change other fluids more often. From what I have seen, SRF costs twice as much as the RBF 600, so if you have to change RBF 600 once mid-season, you are better off with the SRF and save yourself time.
With a V6 1LE, I think RBF 600 is good. RBF 660 isn't really worth it IMO.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-29-2021, 09:39 AM   #12
Norm Peterson
Dunno about that - OP's picture clearly shows DOT4, and his car is two model years later than yours.
Between model years 2020 and 2021 there evidently was a running production change, as it clearly states 'DOT4' in the 2021 Owner Manual.
Originally Posted by 2021 Camaro Owner Manual page 254
Brake Fluid
The brake/clutch master cylinder reservoir is
filled with GM approved DOT 4 brake fluid
as indicated on the reservoir cap. See Engine
Compartment Overview 0 238 for the
location of the reservoir
Thanks for prompting me to update my collection of Owner Manuals.
Norm
Old 08-29-2021, 03:18 PM   #13
UnknownJinX
Norm
Well I stand corrected. The specs have definitely changed for the factory fill. On my 19, only DOT 3 is specified.
Here is some trivia: another difference between the brake fluids, I should point out, is the viscosity change if you drive your car in very cold winters. DOT 3 will have higher cold viscosity than DOT 4, which has higher cold viscosity than DOT 5.1. I didn't notice the change much in the brakes, but if you drive a stick, you can definitely feel the change in the clutch pedal. My old beater Accord definitely rebounded slower after I press the clutch in when it was below -15 C or 5 F outside. It gets quicker as I drive the car. I don't think that many of us drive the Camaro in that kind of cold, hence why I said it's trivia.
Current:
Past:
Old 08-30-2021, 09:13 AM   #14
Silent_H_
Silent_H_'s Avatar
Drives: '21 V6 1LE
I don't plan on tracking it more than a few times a year so I probably don't need to go with the SRF quite yet. I will definitely swap out the factory fill though!
I didn't think about cold weather with the clutch - where I live we often get below 0 temps. I've definitely felt the clutch be "slow" in previous cars on extra cold days. I assume leaving the RBF600 would be ok even during winter though?
