Old 08-27-2021, 01:49 PM   #1
LuciusAelius
Drives: 2019 Camaro 1LT RS 2.0
Paddle Shifters vs full Automatic on the track?
I was wondering which would be better on the track, for my 2019 2.0T. Should I even bother using the paddle shifters (which have a rather delayed responsiveness) or just let the transmission shift on its own? Which is recommended for better lap times?
LuciusAelius is offline   Reply With Quote
Old 08-27-2021, 01:50 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
what are these paddle shifters you talk about? lol
Old 08-27-2021, 02:07 PM   #3
Beescuz
Beescuz's Avatar
Drives: 2021 ZL1 1LE
Never use the paddle shifters. I put mine in track mode/race mode. Car shifts amazingly.
Beescuz is offline   Reply With Quote
Old 08-27-2021, 02:46 PM   #4
aronSlusa
aronSlusa's Avatar
Drives: '16 2SS
I feel forced to use the paddle shifters, on my '16 SS it cannot make up its mind it seems unless I'm WOT. Going into turns it gets too squirly and tries to shift at the worst time.
Wonder if the modes the later model years my '16 does not have would make a difference.
aronSlusa is offline   Reply With Quote
Old 08-27-2021, 02:51 PM   #5
20Bluezl1
I only use paddle shifter on track or street. I can't get use to the auto shifting on the track. I feel like the down shift is not as fast as if I would downshift to slow down.
Old 08-27-2021, 04:44 PM   #6
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
Sure does
ZRacerLE is offline   Reply With Quote
Old 08-28-2021, 09:37 AM   #7
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
He has a LT RS it does not have track mode. If I had an auto I would use the paddles so you can be in the proper gear once you set the car to accelerate out of the corner. Never drove an auto on the track but I would guess if you use maintenance throttle correctly the car should find the correct gear. I guess i would run some laps both ways a see how the car reacts coming out of the corners. I have never seen a post on how the LT 2.0 8 speed reacts on the track but maybe someone who has one can chime in.
dpevans is offline   Reply With Quote
Old 08-28-2021, 07:32 PM   #8
SCCAForums
SCCAForums's Avatar
Drives: Chevrolet Camaro, Ford Mustang
I always use the paddle shifters in my ZLE... when you have 750+ HP and a 200 Treadwear tire... upshifting a little early out of corners allows for the car to put the power down!
Best regards,
Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake
SCCAForums is offline   Reply With Quote
Old 08-28-2021, 08:16 PM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
at VIR in auto mode sometimes the car will downshift one more gear than necessary so I always use the paddles in manual mode. This mostly boils down to personal preference but I'm quite a bit faster in manual mode because some of the extra downshifts over slow the car. You can put down power sooner with the mountain of torque our LT4 has on tap. Experiment and see what works for you.
Old 08-28-2021, 08:23 PM   #10
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
Absolutely only use the A10 without the paddle shifting on the track. I don’t know anybody that uses the paddles on the track.
Home Track: NCM Motorsports Park
Heartbreaker is offline   Reply With Quote
Old 08-28-2021, 09:36 PM   #11
20Bluezl1
There are 2 guys above that do plus me so know you know of 3 guys. Paddle all the way.
Old 08-28-2021, 09:51 PM   #12
Heartbreaker
Andy Pilgrim, Randy Probst, the pros that have driven this car all, to a person, do not use the paddles on the track.
Old 08-29-2021, 01:42 AM   #13
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
OP has a 2.0T, which uses the 8-speed auto, not 10-speed.
I haven't driven automatic Camaro's before, so can't say for sure. My advice is to just experiment around, see if the full auto mode does it for ya. If you want to just mess around or the auto mode doesn't work all that well, then use the paddles.
As for 10-speed, I have talked to a ZLE owner before and he basically told me that it's not bad, but it's no PDK. Maybe it's dependent on the track whether or not if you want to mess around with the paddles for the best time possible. Again, I don't see why you shouldn't just experiment around.
Either way, I am on my 6-speed stick, and I always use my "paddle shifters" to engage the ARM function.
The ZLE owner told me that the 10-speed can also do that from time to time, like shifting mid-corner. Just relaying the info I was told.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-29-2021, 09:56 AM   #14
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Without a track mode I have a feeling that the transmission would default to what would be an appropriate gear for cruising at whatever speed. And then downshift as you start adding throttle for corner exit.
That's really the only way OP is going to find out whether using the paddles or leaving the transmission in auto is going to work best for him.
He'd be best off to pay attention to things like which approach works best for him and whether he can reliably get his paddle commands timed right - and forget all about any differences in lap times for the time being.
Norm
2.0 camaro, lap times, paddle shifters, track driving
