Old 08-25-2021, 08:18 AM   #1
brianchevy
Drives: 2017 SS 1LE and 1987 IROC Z/28
will 20x10 +23mm offset front rub on 2017 SS 1LE?
Friends,
I'm a long time autocrosser of other camaros, now getting more serious about my 6th gen SS 1LE. (3rd gen has become the track car). I'm looking to buy a set of 20x10 fronts and 20x11 rears
i know stock 1LE offsets are
20x10 20mm offset.
20x11 43mm offset.
But the wheels i've selected (and are very lightweight and strong) are
23 offset up front and 43 rear. So.. will the 23 rub fender?
thoughts on the size.. MRR M228..
Thanks!
Brian
2017 Camaro SS 1LE Autocross
2013 Chevy Silverado - Daily
1987 IROC Z/28 RoadRace car
1972 Chevy C10 -
1964 Chevy Nova SS
brianchevy is offline   Reply With Quote
Old 08-25-2021, 11:41 AM   #2
Howdy, neighbor. Mine is a non-1LE, but I have nearly the same wheel setup with MRR017s and PS4S tires. There is a tiny bit of rubbing on the driver side at full lock, see picture (can't even hear it from the cabin when it happens). If push comes to shove, you can eliminate it by adding 3mm spacers, but I'm not sure you'd want to do that on a 1LE that you track.
Hopefully we'll see 1LE owners who can advise here, given how even small differences in suspension geometry could matter here.
Old 08-25-2021, 11:47 AM   #3
foshjowler
foshjowler's Avatar
Drives: 2017 Camaro 2.0T, 91 Miata
I would expect the only place you may run into issues would be the strut. If you do, a little grinding or 3-5 mm spacer should solve the problem. I run 19x10.5 et 22 in the front with no rubbing, but I don't have Mag ride which takes up a little more space.
305 BFG Rivals FTW
Youtube Channel
foshjowler is offline   Reply With Quote
Old 08-26-2021, 08:16 PM   #4
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
Dont mean to thread jack but im about to bite the rim game..and will this set up work and which tirehttps://photos.app.goo.gl/uaLTan6QvCNJZGXv8
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 08-26-2021, 10:05 PM   #5
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
No. A 3mm difference should be fine.
eimarshall is offline   Reply With Quote
Old 08-27-2021, 11:38 AM   #6
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I believe mecorn on this forum is running that offset without spacers and even using 305/30/19 Falkens without any rubbing. You might try to PM him. FWIW, if you want to run 3mm or even 5mm spacers for piece of mind and to take advantage of any slight improvements in front grip that would provide, you don't necessarily have to install longer studs. You could use the Vorshlag open lug nuts. Those may give you enough extra reach in the taper that you can get 6 turns of thread engagement without spacers. They also have the bonus of a 19mm hex that will allow a smaller socket to fit inside the smaller lug nut well of your MRR wheels.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
