08-22-2021, 03:37 PM | #1 |
Drives: 2018 Camaro SS Join Date: Sep 2018
Header Ceramic Coating
is ceramic coating headers really worth it?
08-22-2021, 06:17 PM | #2 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2017
ceramic coating
I have had good and bad experience with ceramic coating on headers. first of was a pair of headers that were purchased from a well known manufacturer and it was bad, with in a year the coating started to peel off and form rust. Second was when I had a set coated inside and out by a local shop for a stock car. This set reduced under hood temps and promoted better flow of the exhaust. Second set took a large amount of abuse and never peeled, chipped or rusted. If i decide to upgrade my 16 I'm going with stainless and may have them coated to reduce under hood temps.
08-22-2021, 08:35 PM | #3 |
Shadow Gray '19 ZLE M6
I had coated headers on my '99 & '00 Trans Ams. Often coated headers are mild steel then ceramic coated. And they definitely rust, especially on a daily driver. I can tell you from experience.
If you were to go with stainless steel headers and then ceramic coated them, that would be the ideal coated setup. Coating does reduce underhood temps. Is it worth it? Depends on your build, but for most I would recommend uncoated stainless headers over coated mild steel headers. And if you want to drop the additional dough, do stainless + coating. I had uncoated stainless headers on my 5th gen SS. I never worried about underhood temps as a bolt-on car.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
08-23-2021, 06:13 AM | #4 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Mine aren’t coated right now (bolt on). But I plan to get them coated before:
A). I track the car or B). I go forced induction. I used a heat sleeve on the steering shaft, used DEI plug boots, moved the wire harness and wrapped the bottom of the coolant reservoir. Haven’t had any issues.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-23-2021, 08:04 AM | #5 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
08-23-2021, 05:32 PM | #6 |
Drives: 2018 ZLE Join Date: Sep 2019
I have my entire exhaust (Kooks headers and catback) coated by PolyDyn and it has cut the heat down significantly. I track the car often during Texas summer which is already brutal so every little bit helps. I jumped a curb on track which scratched/dented one of the headers and the coating is still holding up even after almost a year since that incident.
08-23-2021, 09:32 PM | #7 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2020
My 2002 SS has KOOKs with Jet-Hot ceramic coating and they still look like they are new, installed back in 2006. I selected the same option for my new 2003 Z06. I think it's worth doing.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette| 2016 Corvette Z06 C7.R | 2018 Camaro SS 1LE
08-23-2021, 09:40 PM | #8 |
Sorry I don't have a better pic, but these were my Jet Hot coated headers from my '99 Trans Am after someone rear ended me at totaled the car. I bought a '00 WS6 and moved the mods over. These headers were on the '99 for ~2 years, but she was a daily driver and I live in the northeast -- snow, salt, rain, etc.
08-23-2021, 09:42 PM | #9 | |
08-23-2021, 10:25 PM | #10 |
No, coated mild steel. That was the point I was trying to make in my earlier post. Seems like back when I had my trans ams (mid-2000s) most of the offerings were coated steel headers. Today they're almost all stainless.
The headers in the above pics were Kooks as well. I'm not sure if they offered stainless back then. Or maybe I was just too poor Edit: I actually couldn't remember what brand headers they were, but I found my old mod list from the '02 WS6. Miss that car a lot. Figured I'd share the mods Pro 5.0 Shifter Lou's short stick !CAGS skip shift eliminator SLP Air Lid w/ GREEN Filter 1 3/4 inch Kooks ceramic coated Headers w/ y-pipe dual cutouts off the headers (part of y-pipe) stock WS6 Exhaust System (sounds mean w/ the headers, cam, & heads) NGK TR55 plugs Taylor 10.4mm .409 Race Wires BMR Strut Tower Brace BMR Subframe Connectors Harlan Shift Light (mounted in drivers side defrost spot on a-pillar) GM LS6 Intake Manifold !EGR !AIR Jantzer Ported TB Sure Stop Rotors Hawke Pads SLP Line Lock Moser 12 bolt w/ 4.11s Spohn Torque Arm w/ driveshaft loop UMI Lower Control Arms Patriot Valve Springs (the new ones that have a higher spring rate than the Golds), retainers, seats, locks, seals, chromemoly pushrods Rollmaster Double Roller Adjustable Timing Chain ported LS6 Oil Pump ASP Crank Pulley Patriot CNC Ported "243" Casting Heads 2.00/1.55 OEM valves TSP MS4 Camshaft 239/242 .649/.609 111LSA New Z06 replica rims 17x9.5 all around (the C6 Z06 replicas, not C5) wrapped in 285/40 Good Year GSD3s Alpine Head Unit iPod ready model # CDE-9852
08-24-2021, 06:12 AM | #11 |
MS4 camshaft. That brings back memories. I think I had a G5x2 in my LS. lol
08-31-2021, 09:27 PM | #12 | |
09-01-2021, 06:50 AM | #13 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Yes, keeps underhood temps down, faster cool downs, easier on plug wires and promotes faster flow of exhaust through the header pipes. Also adds to longevity of your headers if tou plan on keeping your Camaro for a while.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
