![]() Drives: 2018 ZL1 1LE Join Date: May 2021
ZLE DSSV Issues/Questions
I've searched and seen easily a handful of you have had issues with front DSSV struts clunking. I purchased a used ZLE with 9,000 miles and now at 11,000 it developed clunking from both sides. I've had it up in the air and checked end links, steering arm and all control arm bolts. I plan to purchase two front struts since it's out of warranty but I was curious if anyone has actually taken one apart that was clunking and actually found the issue. Do they physically break internally or does the nut on the bottom simply back off and fall into the insert? Figured I'd ask before I spend the money if it's something I can take apart and repair. Thank you in advance!
![]() Drives: none Join Date: May 2021
subscribed, at 7K miles but not clunking on street setting.
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
Facepalm
2021 ZL1 1LE
Auto |
#4 | |
Who Needs to KNOW?
I had 2 front DSSV struts replaced under warranty.
These inverted type struts have a nut holding assembly in place and that nuts one some early samples was not properly loctited and comes loose. Easy to duplicate - grab wheel and pull / push aggressively.
![]() Drives: 2022 ZL1 1LE Join Date: Apr 2019
Drivers front failed. Passenger rear failed. Also had a defective front caliper. All replaced under warranty. Car sees heavy track time.
Your short video actually helped me a lot. I'm assuming since yours were covered under warranty you were not able to inspect?
#7 |
I've also seen this image posted by Snakebt6 in another thread. Just wondering why it couldn't be tightened back up as it looks like it just came loose from the insert. As I said, my plan is to order new and tear mine down and diagnose. I'll be sure to post pics.
#8 |
Who Needs to KNOW?
Yeah, I asked to see failed part, but it had been returned/disposed by time I picked up the car. No idea what actual disposal procedure is on $2400 list price part.
#9 |
#10 |
#11 |
![]() Drives: 2017 ZL1 Join Date: Apr 2020
My left front strut was replaced at 1700 miles
2017 ZL1 M6 Silver Ice Metallic
#12 |
![]() Drives: 2019 Chevy Camaro ZL1 1LE Join Date: Nov 2019
Are the replacement struts an improvement or the original design?
#13 |
Who Needs to KNOW?
15,000+ miles later, issue did not resurface.
#14 |
I did see that they changed the part numbers twice, not that it means much with GM. Ordered the struts yesterday. Also, everything I've read ACDelco puts a limited lifetime warranty on these when purchased aftermarket.
