![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
ECR Aug 14th
Ok guys and gals,
Going out to Eagles Canyon Raceway (Decatur TX) on Saturday for Advanced Performance Driving Day. I will be running in the Orange group. Looks like a total of FIVE 25 minute sessions are scheduled including classroom sessions in between. We will be running Counter Clockwise on the 2.7 mile course (my favorite direction). Upgrade I just finished are Stainless Steel Brake lines and the pedal is MUCH more firmer when compared to using the stock lines. Already using HI TEMP brake fluid. Of course the whole theory being using these lines is that you should see at least a slight increase in brake line pressure because stainless wont flex like rubber will. PLUS you wont get the heat deterioration of the lines due to heat over a period of time. Wheels are torqued to 140 pounds. The lines I used are VERY high quality GOODRIDGE 16-21+ Camaro SS/ZL1 Steel Brake Line Kit - Goodridge122991 These aint cheap and will set you back about 200 dollars including shipping but seem to be well worth it. WILL SEE. Tire setup will be as before Pirelli 305 660 18 (26 inches tall) slicks mounted on APEX EC7 18 x 11 wheels ET25 at all four corners. -3.6 degrees FRONT camber and -2.0 degrees rear camber. Tire pressure 30 PSI cold. Using a 5MM spacer up front and also using EXENDED LUG NUTS (Extra Long) that engage about 11 threads on the FRONT Studs and more of course on the rear studs. I rotated the tires since my last track session moving RR (right rear)to LF (left front) and LR to RF. Of course I can do this pretty easily due to the SQUARE setup. PLUS I like the neutral handling I get with a non-staggered setup.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 08-14-2021 at 02:09 AM. |
update
When the rain set in on the second session I was pretty bummed because these pirellis are pretty much a nightmare in the rain. BUT, the track did dry with each session thereafter and I managed a 2.08.77 in the last session I did.
If you havent tried out the ECR track days I would highly recommend it. Brad puts on a fun event and they have some some talented instructors.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 08-15-2021 at 02:29 AM. |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Keep an eye on your Goodridge lines. I have had one of those blow out on me at a track. It had to be installed at an angle on a Mustang I previously owned, and it burst at the junction where the epoxy coating met the mounting point which attaches to the caliper.
#4 | |
Well thats good to know, Hopefully that was just an one off incident .
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
