Old 08-13-2021, 09:03 AM   #1
FoundNemo
Drives: 2019 ZL1
Hitting rev limiter with tune
My buddy noticed that in auto mode on his ZL1 A10 (stock rev limiter, untuned TCM, stock fuel cuts, etc) with his headers and tune from the local shop the car will bump the limiter if you floor it on the hwy, which it did not do stock. In gear shifts fine without any issues.
Any thoughts on why that might be since the TCM wasnt tuned, intake is stock, TB is stock, pulley and blower are stock, TCM is untuned, shift points werent changed nor the stock rev limiter or fuel cuts of any sort?
Would raising the rev limiter 100rpms be a safe way to give it breathing room or is that not a good idea on an 18 ZL1 for longevity.
FoundNemo is offline   Reply With Quote
Old 08-13-2021, 09:16 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
When you make more power the goal is to increase the rate of acceleration. When the car accelerates faster then you need to give the TCM more time to make the shift. So Ideally you command a lower shift MPH to make the shift at the same RPM before the power increase. Since the TCM isn't tuned now you have to raise the limiter in order to get a clean shift at the same commanded shift points since most if not all GM transmission controllers primarily shift off of commanded MPH not RPM.
Old 08-13-2021, 09:33 AM   #3
Vigilante375
Drives: 2018 Camaro ZL1
So you are saying that with the car in D and your friend floors the throttle, the engine bounces off the limiter?
But in gear (do you mean manual mode?) It shifts fine?
At what speed is he flooring it? It could be that he is flooring it right where the car would down shift to a speed where there is no room for the car to realize it's going to bounce off the limiter.
Meaning, you go 100% throttle at 55mph but the car shifts to 3rd and 3rd maxes out at 62mph so the car has no time to realize it should have shifted to 4th so it bounce off the limiter for a moment. Just like King said, is making more power and doesn't realize it needs to shift to a lower gear.
Sounds to me like the shop didn't think about tuning the TCM or your friend didn't want it tuned or didn't know.
Old 08-13-2021, 10:54 AM   #4
wnta1ss
Drives: 2017 Camaro 1SS
Some big shops are supposedly telling guys that trans tuning is unnecessary for the A10 ZL1 unless you change the camshaft. So this customer probably did not get the whole story on what tuning can do.
Old 08-13-2021, 02:37 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
Tire spin equals rev limiter hits, particularly in 1-3. If it hits the limiter while not spinning the tire it has other issues.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-13-2021, 02:44 PM   #6
FoundNemo
Drives: 2019 ZL1
Yea TCM tuning was optional. 80mph WOT will bump the limiter. Is it safe to up the limiter by 100rpms to give it breathing room in the meantime?
Old 08-13-2021, 05:16 PM   #7
wnta1ss
Always a risk to modify stuff of course. But if the owner is comfortable with it, some do raise the rev limiter to some extent. What are the current settings (several places in the tune that affect this)?
Old 08-13-2021, 05:47 PM   #8
KingLT1
KingLT1's Avatar
Either raise the limiter or tune the TCM. I moved my limiter up to 7k rpm...not going to hurt anything. Ideally it should be 2-300rpm above the shift point. you have to change 4 different areas in the tune to raise the limiter. Extreme, In-gear, oil temp, Startup Modifiers(cold engine)...etc
