Old 08-10-2021, 12:40 PM   #1
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
Dealer says fuse box needs to be replaced
So my car completely died on Sunday while driving and nothing worked. Had the car towed to the dealer and they found a 30amp fuse blown in fuse box in the trunk. Just that one fuse rendered the car a paper weight. Absolutely nothing worked. With that fuse changed they got the car running again but wanted to investigate what the fuse blew. After some diagnosis they had the fuse blow again and determined that the entire fuse box needs replacing. Shit part now is that box has to come from somewhere in the US and could take 2 weeks to get the part.
Has this happened to anyone else?
For context this is a 2018 sle with 15000km (9300miles)
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 08-10-2021, 12:44 PM   #2
redcoats1976
this sounds rather odd.when you look at the box does it look rusted/water damaged?
redcoats1976 is offline   Reply With Quote
Old 08-10-2021, 12:53 PM   #3
Camarentino
I’ve never seen the fuse box personally
Old 08-10-2021, 07:01 PM   #4
machinis
Drives: 2018 SS 1LE
This happened to me but it was an obvious reason. After installing long tube headers, I did a piss poor job on reinstalling the starter positive cable, which came loose and damaged the fuse box.
machinis is offline   Reply With Quote
Old 08-10-2021, 08:02 PM   #5
It does have a series of large fuses that are part of the fuse box assembly itself. If one of those is blown, you need to replace the unit indeed, so their diagnosis may well have been correct. Parts shortage sucks, too
Old 08-10-2021, 08:23 PM   #6
3.8TransAM
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula
Call it what it is, a piss poor design and all the cheap ass manufacturers are using it.
When you can't replace fuses and relays because they are built into a fuse box, someone needs their ass kicked.
3.8TransAM is offline   Reply With Quote
Old 08-10-2021, 09:58 PM   #7
Camarentino
Newer technology is definitely not always better I guess
Old 08-10-2021, 10:01 PM   #8
Camarentino
Originally they had said the starter may have been the cause but then determined it was the fuse box instead
Old 08-10-2021, 10:04 PM   #9
Camarentino
Bright side is that the fuse box is only something like 150 bucks and few hundred labour just the down time in the heart of a very short Canadian summer really blows
Old 08-11-2021, 09:23 AM   #10
ctrlz
So which fuse was it? It might indicate on the service record.
Overall, this sounds like it might be a problem from water intrusion in the trunk and corrosion of connectors. Did you even take a look?
Old 08-11-2021, 09:56 AM   #11
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
I've heard issues of water infiltration causing the fuse panel to go bad on 6th gens before.
Jaxcam02 is offline   Reply With Quote
Old 08-11-2021, 10:01 AM   #12
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Wow. Still figuring out how to build a trouble-free/maintenance free fuse box...lol...
With the all electric EV future just ahead, what could go wrong?...lol
Old 08-11-2021, 10:14 AM   #13
ctrlz
On a boat ,you put a gasket on it and bolt it closed. I'm not sure why the same strategy would not work for cars. What fraction of car buyers actually changes an automotive fuse or relay anymore? 0.00001%? And that is the same fraction who already own enough tools to open a sealed fusebox.
Old 08-11-2021, 10:18 AM   #14
BrandanK
Drives: 2021 Camaro SS 1LE
It is all about cost. Why add cost to each vehicle when only a fraction of a percentage will have a problem.
BrandanK is offline   Reply With Quote
