Old 08-09-2021, 03:09 AM   #1
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Pray stage 1 heads
Re posting with more parts.
*Stage 1 pray cam
*Tsp push rods
*Fuel pump lash cap
*Stage 1 heads (fully assembled) with about 7300mi since port job. These have brand new upgraded valve seats that he uses, (stock ones are a known problem) brand new OEM valve guides both with 0 miles since replacement.. Comes with tsp pac .660 dual valve spring kit.
He no longer hand ports except for in house builds (unless he changed his policy). Skip the wait and down time.
Asking 2300.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 08-11-2021, 11:41 AM   #2
chrisgood1
Drives: C7 Corvette
Reason for selling? Which heads are you switching to?
chrisgood1 is offline   Reply With Quote
Old 08-11-2021, 09:15 PM   #3
Dubchitts
Dubchitts's Avatar
I thought my motor got lucky and had the heads fixed. Cleaning to re install the heads I discovered some scratches on the top side of my cylinder. So I'm re-sleeving and building a 427 and am gonna need bigger valves. Probably leaning towards PRC for now
"Spitfire" 427ci
Old 09-22-2021, 02:48 PM   #4
L78toLT1
L78toLT1's Avatar
PM sent
Baby Blue
Old 01-26-2022, 08:16 AM   #5
Dubchitts
Dubchitts's Avatar
Updated sale with more stuff
"Spitfire" 427ci
Old 01-27-2022, 01:24 PM   #6
Duramacr1
2Spdsy
Duramacr1's Avatar
Drives: 2021 Camaro LT1 A10
Very interested . How much power did you put down with that combo?
Duramacr1 is offline   Reply With Quote
Old 02-01-2022, 10:27 AM   #7
Dubchitts
Dubchitts's Avatar
I never ended up being able to use the Dyno on the final iteration. I would guess 550-560 on the atomic air force IM, 570ish on the Hiram?
I was able to go 10.8 in a m6 with factory 6pistons, and the only weight reduction being my pass seat out only so I could carry my slicks to the track lol. I'm sure it could do better if I had more seat time but the dailys an 18 wheeler
"Spitfire" 427ci
Old 02-08-2022, 10:20 PM   #8
Dubchitts
Dubchitts's Avatar
Bump
"Spitfire" 427ci
Old 02-28-2022, 05:48 AM   #9
Dubchitts
Dubchitts's Avatar
Bump. Boxed and ready to ship
"Spitfire" 427ci
Old 03-13-2022, 09:11 AM   #10
Dubchitts
Dubchitts's Avatar
Bump
"Spitfire" 427ci
Old 03-13-2022, 10:32 AM   #11
991.1le
Drives: 2018 SS 1LE
What happened to these exactly? You mentioned having the heads fixed.
991.1le is offline   Reply With Quote
Old 03-13-2022, 10:41 AM   #12
Dubchitts
Dubchitts's Avatar
The oem valve seats had chipped.
"Spitfire" 427ci
Old 03-13-2022, 11:18 AM   #13
991.1le
Drives: 2018 SS 1LE
PM sent. One other question. How many miles on the springs?
