![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
DYNAPACK CHASSIS DYNO
Any thoughts on this dyno? It showed my car getting 688 whp. That seems a little excessive. What do you all think?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Pick a number, Dynos are tuning tools. Not soothsaysers....
2012 Yukon XL Denali w/ 6.2 AWD |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Not out of line at sea level and e60 blend with your the JRE 125 mods.
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Dynapack dynos are typically 5-10% higher then dynojets as to simply how they get the reading from the hub and not from the wheels on a roller.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Dynapacks rate higher than other dynos, otherwise its a tuning tool.
