![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
ZL1 130+ mph Acceleration
I am curious everyone's thoughts on why a stock ZL1 seems to not maintain its acceleration rate at 130+ mph compared to other similar cars.
For example: 2017 Camaro ZL1 A10 per C&D: 60-130 in 9.0 seconds (MT was 8.9 sec, for comparison). 2018 Mustang GT A10 per C&D did 60-130 in 11.0 (MT was slower, for comparison) ZL1 is 22.2% quicker than the GT (comparing the better GT to the slower ZL1 time). ZL1, same test, does 100-130 mph in 5.0 sec, while the GT did 100-130 mph in 6.3 sec. For that split the ZL1 is 26% quicker. Better than the 60-130 test because the ZL1's higher power is more effective at resisting the increase in drag at higher speeds. Nevermind that the GT is closer to the ZL1 than it should be given the lbs/hp ratio (6.0 vs 8.3 = 38% difference), which I think is explained by a slight underrating of the Gen 3 Coyote and the extremely flat high end hp curve, take a look at the 130-150 mph times: ZL1: 6.0 sec GT: 6.9 sec Now, this is only a 15% difference, much closer than one would expect and the GT is closing the gap; generally more powerful cars just continue to separate at a quicker and quicker rate as speeds climb, i.e., normally, I would expect a 30% improvement for the ZL1 over the GT, not a drop to only 15% quicker. I have seen this with other cars as well, where they seem to start to close the acceleration gap at speeds above 130 mph with the ZL1. One more example: GT500 (base), again, per C&D: ZL1: 60-130 = 9.0 GT500 60-130 = 7.6 GT500 = 18% quicker ZL1: 100-130 = 5.0 GT500 = 4.1 GT500 = 22% quicker ZL1: 130-150 = 6.0 GT500: 130-150 = 4.1 GT500 = 46% quicker - a much larger gap compared to what you would expect given the 100-130 splits. The ZL1 is falling on its face at 130+ mph. Why? I have a couple of theories but figured I'd ask the wider audience. Theory #1: LT4 IC HEXs are undersized and it heat soaks after a certain amount of continuous full throttle and pulls timing as MAT rise. In this case, after about 12-13 seconds of WOT. Dodge and Ford may have more effective intercooler HEXs, reducing that effect, and the GT doesn't have the issue. #2: Car shifts into 7th (1:1) and with 2.85 rear end, kills acceleration. #3: While the magazines adjust for DA, maybe the ZL1 was tested in hotter air, and the GT500 and GT were tested in cooler weather. They can correct for DA for the times, but that doesn't account for the lost timing at high MATs due to high ambient air temps. The LT4 pulls a lot of timing as MATs climb. #4: Some combination of the three above (or all of them) I've ruled out drag because I would think the GT500 has similar drag to a ZL1. Thoughts?
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Your splitting hairs, ZL1 w A 10 is still faster.
2012 Yukon XL Denali w/ 6.2 AWD |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
What are the headwind & tailwind components for each test you listed.
Air resistance increases expeditionary as speeds increase and having a good headwind or tailwind can either help or hurt those numbers. What is the CO of drag on all the cars listed as well? You really have to dig beyond car data as speeds increase, aerodynamics play a huge role as well.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#4 | |
Obviously aero plays a role, but the GT500 likely has similar drag to the ZL1, close enough not to show such a drastic difference between 100-130 and 130-150. Aero doesn’t explain it, there’s more to it than aero differences.
2021 Camaro ZL1 A10
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
my previous '17 and current '21 are about the same... after 130mph they are pretty dead feeling. 7th gear in the 10 speed is a large drop off. I feel 7th should be steeper and 8th should be 1:1. A stock GT500 leaves me on the straight a bit and it is definitely worse above 130mph...no worries as I catch up in the braking zones.
![]() Drives: 2017 ZL1 Join Date: Apr 2020
I will put an M6 against the A10 in anything except a drag race.
2017 ZL1 M6 Silver Ice Metallic
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
HP matters when accelerating at high speeds. The Hellcat makes 717-797hp depending on which variant you get, and the GT500 makes 760hp, those HP ratings matter as the car is trying to overcome drag. I'd like to see a modified 700whp ZL1 compared to a Hellcat Redeye and GT500 in some high speed tests.
#8 |
![]() Drives: 2019 ZL1 Join Date: Oct 2019
All cars equal and traction/weight out of the equation for drivers/passengers, M6 will lose every time unless A10 driver is manually shifting and or delayed. But, M6 is better driver car I agree. A10 stays in powerband more efficiently.
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
Just wait for Mr. Whole's brilliant incoming answer. He races 180mph+ all the time so he will tell you everything.
Old Ride: 2016 Callaway SC630 Camaro SS
#10 |
![]() Drives: 87 GN, 05 GTO Join Date: Aug 2011
Its most likely a combination of extra down force compared to the 5.0, the extra RPM the 5.0 has extending those gears before hitting 7th, extra rolling resistance of the wider tires and wheels on a ZL1 etc.... A friend with a stock Zl1 did 60-130 in 8.4 on a 90* day so magazine test, while accurate for that particular car on that particular day are not always a true representation of their capability.
1987 Buick Grand National 10.70@128
2005 MBM 6 spd GTO 7.00@ 103.7 mph 1/8th |
#11 | |
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Add some power and you’ll be easily into
The 6’s and 5’s 60-130
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#13 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
For what it's worth I took a 60-165 video from Mexico and edited down to 60-130. It came out to 8.8s including the gear drop in there.
https://youtu.be/gSb_SttJfhU
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#14 |
Here's more examples, info. from the test published today by C&D on the M3 Comp vs Alfa Giulia:
'21 M3 Comp: 60-130 mph: 9.3 sec (3% slower than ZL1) 100-130 mph: 5.2 sec (4% slower than ZL1) 130-150 mph: 5.5 sec (9% quicker than ZL1) '21 Alfa Giulia Quadrifoglio: 60-130 mph: 10.3 sec (14.4% slower than ZL1) 100-130 mph: 5.7 sec (14% slower than ZL1) 130-150 mph: 6.5 sec (8% slower than ZL1) The ZL1 should be getting quicker and quicker compared to these lower powered cars as speeds climb, not as in this case noticeably slower than an M3 Comp 130-150 mph. And the Giulia should not be closing the gap vs the ZL1. Obviously, with the M3 Comp running 1/4 mile in 11.6 @ 124 mph it is a lot more than 503 crank hp, but the ZL1 is quicker below 130 mph, yet slower above 130 mph. I might chalk this up to the one test by C&D having a ZL1 that was a bit slow, but MT ran the exact same time and trap speed (11.5 @ 125 mph as C&D, however w/ 91 octane), and I noticed the same large drop off above 130 mph in the ZLE A10 test by C&D (vs. the GT500 and Redeye in 2019). Again, aero can't explain it because the GT500 CFTP has a large wing and aero bits as well, and was MUCH quicker above 130 mph than the ZLE. More so than the 110 hp Delta suggests. Anyway, I'm still sticking to my theories #1 and #3 above. I think it's a combination of undersized HEXs that can't keep up for long WOT applications + hotter ambient air testing conditions (can't make up loss of timing with DA corrections) + subsequent timing loss = slower at the end of a long WOT pull.
2021 Camaro ZL1 A10
