Old 07-30-2021, 09:57 AM   #1
FarmerFran
FarmerFran's Avatar
Good Wheel "Brush" or such for
Currently I am using a good cloth but getting up and around the calipers is a PITA
Anyone have a good way of cleaning the inside of the wheels, without taking them off? I have a good bit of room between the spokes but not so much the caliper.
(Just pretend they are Camaro wheels)
<Insert Cars You Own Here>
Old 07-30-2021, 11:09 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i only take my wheels off to clean them after every track day but other than that i dont care...
Old 07-30-2021, 11:52 AM   #3
Budman51
Drives: 2023 SGM 1SS
https://www.autogeek.net/ezdebrfca.html
This is what I use on my SS split spoke wheels. Works fantastic.
2023 1SS SGM A10 NPP
Budman51 is offline   Reply With Quote
Old 07-30-2021, 01:33 PM   #4
Trochoidal
Drives: 2017 Camaro 2SS A8
I use a gong brush with the long handle to clean the barrels. The handle is plastic and does good with not hurting the finish on the wheels. I did get the shorter version too for the face of the wheel, but find a rag works better.
I’ll clean as much of the barrel as possible on all four wheels because the calipers get in the way. After that I’ll hop in the car and move the car so the valve stem rotates 180°. This will expose the dirty area that was at the caliper location to allow cleaning the remaining area. Maybe everyone already cleans their wheels this way. Before this car I’d pull them to clean barrels.
https://www.amazon.com/HDX-20-Gong-S.../dp/B00KXBIT9K
The HDX brand can be found at Home Depot. I believe that’s where I purchased the two I have now.
https://www.homedepot.com/p/HDX-20-i...DXRM/204357154
Also, I had the type that was posted above. The portion that holds the bristles is made from what I’ll call twisted metal coat hangers. It bent and was thrown away. After the fact it should have never been purchased because of having the metal material holding the bristles.
Old 07-30-2021, 01:48 PM   #5
FarmerFran
FarmerFran's Avatar
Currently I do the move the car method. But my laziness is overwhelming sometimes and I hate to get in the car all sweaty and dirty
Old 07-31-2021, 11:51 AM   #6
6spdhyperblue
Drives: 2SS 1LE
I use this one too. Works great
Old 07-31-2021, 12:35 PM   #7
KirkH
Pro detailer here.
I use several tools for spoke wheels:
Wheel woolies, power wheel woolie, microfiber glove, Viking metal free wheel stick and the Atlasta brush. All of these are easily found on Amazon or Autogeek.
Old 08-05-2021, 08:24 AM   #8
USMC SGT
Drives: 2021 1SS 1LE
I've been using these and they work great. The smaller one can even squeeze between the 1LE calipers and wheels
https://www.chemicalguys.com/rimpaca...%20Suggestions
USMC SGT is offline   Reply With Quote
Old 08-05-2021, 12:31 PM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
For most of the outer rim, spokes, caliper, and front end grillework: Chemical Guys Gerbil Brush.
https://www.amazon.com/Chemical-Guys.../dp/B00BJCHX8K
For the wheel barrels, wheel woolies. Handles are long enough to get around even the big ZL1 calipers without having to move the car.
https://www.amazon.com/Dr-Beasleys-C.../dp/B008S0MO2G
For the lug nuts and easy-to-access-through-spokes parts of the calipers, the CG detail brush:
https://www.amazon.com/Chemical-Guys.../dp/B00N8RI67Q
Fran - the above should make light work of your wheels, as you have nice open spokes.
Old 09-06-2021, 09:01 PM   #10
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I like the speed master brushes. They have a large and small and the small should get in there.
dpevans is offline   Reply With Quote
Old 09-09-2021, 01:52 PM   #11
ctrlz
This looks like a knockoff of the speed master product. But works for me.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ctrlz is online now   Reply With Quote
