Old 07-28-2021, 08:32 AM   #1
Smokin19
Drives: 19' ZL1 A10, w/pdr
Paint removal
Has anyone removed the paint on their carbon fiber hood cap? Do you think it could be done cheaper than buying another?
Smokin19 is offline   Reply With Quote
Old 07-28-2021, 08:45 AM   #2
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
I thought it was wrapped
Old 07-28-2021, 09:09 AM   #3
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
gave my view in gtfoxy's thread
Old 07-28-2021, 09:16 AM   #4
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
It was my understanding that the painted ones were flawed in some way. The carbon underneath may not be perfect. It'll also probably be missing the special clear coat put on the carbon ones.
Old 07-28-2021, 09:34 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Like was already posted, from what I recall in the 5th Gen days, only the "perfect" inserts were left unpainted. Angles and straightness were the reasons that stand out in my memory. Sure - you could probably sand-off the paint, but I suspect you'd have to spend timing sanding and clear coating the insert, assuming you have a good one. I know that the ECF-inserts get polish because there's still residue on mine that is visible.
If remember an article when C6 ZR1s were first introduced with ECF, and there were at least a couple articles stating GM said they spent $60K a gallon on UV-resistant clear coat for those parts so leaving them in the sun wouldn't degrade the CF. I think there was probably a decimal mis-placement, but, still, that is a problem, so protecting that freshly sanded, clear-coated, and polished insert should be the minimum considerations.
'20 ZL1 Black "Fury"
Old 07-28-2021, 09:37 AM   #6
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Just buy another or try to trade someone. Getting the paint off and trying to get the exposed look is too much work, money and potentially damaging to the carbon fiber.
Jaxcam02 is offline   Reply With Quote
Old 07-28-2021, 12:14 PM   #7
Scottyz
Scottyz's Avatar
Obviously I’m wrong here. I could have sworn I saw a thread on somebody taking a wrap off one. My apologies to the OP for the misinformation.
Old 07-28-2021, 12:33 PM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
You asked a similar question in the other thread. My answer: https://www.camaro6.com/forums/showp...1&postcount=46
TL/DR: Don't do it. It will almost certainly look like crap, resulting in trashing an otherwise perfectly good part. It's WAY less trouble to buy a new exposed CF part. Or just wrap the one you have if you're just changing colors.
Cheapest route is likely buy used from Ebay for $500 and throw a couple hundred more at a good body shop clean it up for you.
https://www.ebay.com/itm/144067941001
Old 07-28-2021, 12:46 PM   #9
Smokin19
Doing some research gave truth to your post. Good info.
Old 07-28-2021, 03:12 PM   #10
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
That's the hood itself on the ZLEs not the center insert portion.
